belt stops
2 replies to this topic
#1 nittanylyn OFFLINE
nittanylyn
  • 26 Thanks
  • 22 posts
Posted April 25, 2016 - 07:43 PM
Has anyone had experience making belts stops for the walk behinds? And if so, what is the best way to go about it? I know that some are longer on the end, some have a slight bend in the middle, and all have the loop on the end
Seems like it would need to be a pretty heavy gauge wire but also be able to maintain some rigidity to hold the belt close to the pulley.
Any help in advance is appreciated.
Greg
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 25, 2016 - 09:05 PM
its a 3/16 rod not a wire. easiest way to make them if you don't have a bender, is to weld a flat washer on the end of the rod. making the 90* bends is easy in the vise. Some tractors also used a curved piece of metal with tabs welded on that went around the crank pulley.
  • Alc and nittanylyn have said thanks
#3 nittanylyn OFFLINE
nittanylyn
  • 26 Thanks
  • 22 posts
Posted April 26, 2016 - 05:28 AM
Thanks so much. I will let you know how it works out.
