Got my 1054 out plowing (dirt, not snow)
6 replies to this topic
#1 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,173 Thanks
  • 694 posts
Posted April 24, 2016 - 10:56 PM
I just put the finishing touches on some homemade wheel weights and got them mounted. They worked out to 24lbs each. I also have 40lbs of Rv anti-freeze in each rear tire, for a total of 64lbs per side. I bought the plow off Kijiji late last summer. The guy I got it from had built a new adjuster link for it out of aluminum. It actually worked fine until I tried to reverse with it in the ground, then it ripped out the threads. I grabbed a piece of steel that had an offset bent into it out of my scrap pile, cut it to length, welded a nut  onto it and was back in business. I am sure many of you have seen straighter furrows, but I am happy with the results. I did run out of gas, or I would have finished. I was in second gear, low range, about 3/4 throttle and she did a great job in my opinion.
Jim
  • Bolens 1000, Alc, KennyP and 9 others have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,203 Thanks
  • 4,587 posts
Posted April 25, 2016 - 04:01 AM
Nice job plowing!
The wheel weights look good too! Brake rotors?
  • boyscout862, CanadianHobbyFarmer and 637Yeoman have said thanks
#3 KennyP OFFLINE
  • 35,103 Thanks
  • 44,122 posts
Posted April 25, 2016 - 04:16 AM
Good to see dirt being turned over!
  • boyscout862 and CanadianHobbyFarmer have said thanks
#4 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,173 Thanks
  • 694 posts
Posted April 25, 2016 - 07:07 AM
Nice job plowing!
Yes they are brake rotors, with some concrete added. They were originally on the front of the truck in the second picture. I welded pieces of pipe over 4 of the original bolt holes before I poured the concrete. This way the bolts are holding onto steel, not concrete
Jim
  • limebuzz said thank you
#5 propane1 OFFLINE
propane1
  • 7,988 Thanks
  • 3,862 posts
Posted April 25, 2016 - 09:42 AM
Looks like good fun, hope to be plowing or tilling within the next week here. Great job on the weights and plowin.
Noel
  • CanadianHobbyFarmer said thank you
#6 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted April 25, 2016 - 09:47 AM
Very ingenious weights :thumbs: Turning dirt is a learning curve, your well on your way :thumbs:
#7 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 7,105 Thanks
  • 2,321 posts
Posted April 25, 2016 - 11:43 AM
Looks good - glad you got to enjoy some seat time
