case 222 lurch ! help
4 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,081 Thanks
  • 2,369 posts
Posted April 24, 2016 - 05:06 PM
What would couse a case 222 hydro drive tractor to lurch when driving? Seems to have plenty of power and the hydro tank is full.
Pete
#2 boyscout862 ONLINE
  • 12,160 Thanks
  • 8,881 posts
Posted April 24, 2016 - 05:10 PM
Mine does because it needs a tuneup or its valves adjusted(next week). Good Luck, Rick
#3 cmn135 OFFLINE
cmn135
  • 36 Thanks
  • 55 posts
Posted April 24, 2016 - 08:22 PM
What do you mean full. If by full you mean all the way to the top you have too much fluid. Depending on your year some go to 2" from the top some around 4" from the top.
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,454 Thanks
  • 1,104 posts
Posted April 24, 2016 - 08:53 PM
There should be an adjustment for that on the rear end but I can't remember where
#5 petrj6 OFFLINE
petrj6
  • 4,081 Thanks
  • 2,369 posts
Posted April 25, 2016 - 03:55 AM
   Ok so I took it on faith from the seller that the tank was full, when I got it home I looked it over and discovered that the oil tank only had about 1" of oil in there.  put some more oil in it and of I went !!!!  easy fix, thanks guys
        Pete
  • cmn135 said thank you
