v4-10 is alive again
5 replies to this topic
#1 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted April 24, 2016 - 10:56 AM
after acquiring the v4-10 in the fall I have now had some time to go over it well and get it going again.  PO had changed out the ignition but either it was bad too or was fried somewhere along the way.  I replaced it with one of dale colvert's units which was the same thing I had to do on my hd-12.  stator was also bad and got a replacement for it pretty cheaply.  trigger pins on the flywheel were incorrect so I got a new set and installed them.  ignition switch was wrong (also didn't have a key) so I put the correct switch and rewired everything correctly by the manual.  cleaned the carb bowl, put some gas to it, and it fired right up and runs nicely.  shifter handle was bent and had to straighten it to allow it to shift into all gears but its in good shape now.  from the earlier post regarding the mounting hardware for the front blade, I finished making the correct parts and installed the blade on it and everything works as it should.
  • sacsr said thank you
#2 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted April 24, 2016 - 10:58 AM
Pictures, or it didn't happen!! Lol
  • IamSherwood, sacsr, boyscout862 and 2 others have said thanks
#3 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted April 26, 2016 - 06:03 PM
unfortunately no pictoral proof of this either.  hope it still runs when I get back!  will take some of the whole outfit next time im down there.  im realizing that im slacking on photos for my archives.
#4 KennyP ONLINE
  • 38,299 Thanks
  • 45,899 posts
Posted April 26, 2016 - 06:06 PM
YEP!
#5 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted May 03, 2016 - 03:13 PM
took a few pictures this weekend:
  • LPBolens, KennyP and jerseyeyes have said thanks
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 19, 2016 - 11:15 AM
Sweet!!!
