Bolens 900 Seat Recover Project
86 replies to this topic
#61 ClassicBolens OFFLINE
ClassicBolens
  • 1,384 Thanks
  • 496 posts
Posted May 26, 2016 - 03:29 PM
The 2 piece looks fantastic.
  • blackjackjakexxix and 29 Chev have said thanks
#62 LPBolens ONLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted May 26, 2016 - 04:53 PM
I too think the 2 piece cover looks just fine, and will probably hold the appropriate shape better.
#63 toppop52 OFFLINE
toppop52
  • 5,253 Thanks
  • 4,757 posts
Posted May 26, 2016 - 09:25 PM
The 2 piece approach will always be easier and look better on complicated, compound shapes. You just can't duplicate a heat mold in your garage.
  • LPBolens and 29 Chev have said thanks
#64 toppop52 OFFLINE
toppop52
  • 5,253 Thanks
  • 4,757 posts
Posted May 27, 2016 - 08:19 AM
To me the cut and sew is a more custom, quality appearance anyway, though a bit more time consuming. By the way, that stitching is excellent! :thumbs:
  • 29 Chev said thank you
#65 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 06, 2016 - 05:59 PM
Let the seats sit for a while to let the glue dry and then set them out in the sun on Saturday for about half an hour.  The one piece cover (first picture) stayed stuck this time - the two piece let go in a couple of spots (second picture) which did not surprise me as the foam had already been glued once with the weaker adhesive and probably did not get a good bond with the stronger glue.  It still looked ok but it bugged me so I pulled the welt out and used some 3M weatherstrip adhesive to stick it back to the foam while it was out in the sun - it seemed to stick very well and formed to the foam again.  Left it out for another half hour and then checked it again Sunday morning and it seems to be stuck still so I squeezed the edge back down on both the seats.
  • LPBolens, Alc, blackjackjakexxix and 2 others have said thanks
#66 Chubien OFFLINE
Chubien
  • 645 Thanks
  • 399 posts
Posted June 06, 2016 - 06:02 PM
That looks really good!
#67 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 06, 2016 - 06:05 PM
Today I masked out the seat with the one piece cover and then I decided to try mounting it on the engine stand so I could rotate it while I was painting it.  I used Chubien's third seat to set up the hole spacing and then I mounted the masked seat on to it, did a bit of prep work to the outside edge and then I repainted it white again.  This time I left the vinyl sticking out and will have to trim it when the paint dries - not sure how well the very edge of the metal lip got painted as the vinyl tended to roll up and cover it in a few spots.  Will have to see what it looks like after it dries - may have to touch up the lip edge.
#68 ClassicBolens OFFLINE
ClassicBolens
  • 1,384 Thanks
  • 496 posts
Posted June 06, 2016 - 07:00 PM
Seriously, that seat looks outstanding. Probably better than it was when it was new.
#69 fonz3482 OFFLINE
fonz3482
  • 1,358 Thanks
  • 787 posts
Posted June 07, 2016 - 08:26 AM
Loving the 2 piece seat cover. For me the 2 piece looks better for some reason. Now I just gotta get myself a 900 so I can send you a seat to do! Also, you have the 1st seat pan rotisserie I've seen. Lol! Great idea.
#70 C130A Flight Engineer OFFLINE
  • 181 Thanks
  • 151 posts
Posted June 07, 2016 - 04:56 PM
And to what address do I send the seat pan for my 900? Your hired.
#71 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 07, 2016 - 05:19 PM
Sent you a pm
#72 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 07, 2016 - 05:23 PM
Unmasked the seat with the one piece cover and trimmed the vinyl along the edge using a razor blade.  The paint actually did a good job of covering the edge so it looks like I should not have to touch up any spots and the seat doesn't look to bad in my opinion considering it has been painted again.  Here are some pictures of the results.
  • LPBolens, Alc, blackjackjakexxix and 1 other said thanks
#73 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 07, 2016 - 05:32 PM
Then I masked out the second seat with the two piece cover and did some work around the edge and on the back getting rid of some imperfections and pin holes with body filler.  In between coats of filler I managed to find some time to sew up another two piece cover that will be going on Robert's seat that he got with his $75.00 parts tractor.
  • blackjackjakexxix and WrenchinOnIt have said thanks
#74 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 09, 2016 - 06:29 PM
Got the second seat with the two piece cover painted yesterday, unmasked and the vinyl trimmed today.  I am really happy with the way this cover looks against the white seat pan.  Here are pictures of what it looks like outside on a nice sunny day.
#75 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 8,632 Thanks
  • 2,843 posts
Posted June 09, 2016 - 06:38 PM
Then I cut new padding and glued it on to the third seat that Robert sent me from his $75.00 tractor find.  Since I had to order some more foam I went with 1" thick foam instead of gluing two 1/2" thick pieces together to make the padding - it was a little trickier to form to the seat pan at the rear curves but I think it still looks ok.  Once I had it glued in place and the outer edge trimmed I glued the pleated area of the new cover and stuck it in place.  Will let it sit overnight and then try and glue the rest of the cover to the padding tomorrow.  If you look closely at the front pleat you will see that it goes straight across rather than curving back along the sides at the outer edge - I think this will look better when the seat is finished.
  • WrenchinOnIt said thank you
