Sears DLT ?s
6 replies to this topic
#1 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted April 23, 2016 - 06:54 PM
I have a Sears DLT mower that has the 25HP B&S Intek engine. I have been looking for a troubleshooting chart for the engine. It is: MODEL  445777
TYPE      0129  E1
CODE     000731 YG
The issue is it runs great until I turn the PTO on. Then it starts cutting out, flooding, and all around runs poorly. Once you turn the PTO off, it takes a few and it starts running great again. I have no idea if the vales have been checked or the plugs replaced on this machine. I plan to R&R the plugs and set the valves soon. Just wondering if anyone else has had this issue with the Intek.
  • marieck18 said thank you
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted April 23, 2016 - 07:14 PM
Both cylinders firing?
#3 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted April 23, 2016 - 07:33 PM
Seems like one backs off when under a load. Lots of black smoke too. Need to see a parts breakdown, wonder if the plug wires are getting bad?
#4 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 23, 2016 - 08:02 PM
   Not really the same as yours but I got a Jacobsen a few years back doing the same thing and it turned out to be the wires going to the clutch where frayed and wore thru so when you turned the clutch on it shorted the system and made the tractor run like crap.  just something to look for, good luck.
        Pete
#5 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted April 23, 2016 - 08:06 PM
        Pete
Hadn't thought of that! Worth checking out! Another thing I plan to do is check the battery voltage before and as it does this!
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted April 23, 2016 - 09:43 PM
May be of some help here http://www.briggsand...5777-0129-E1//1
#7 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted April 24, 2016 - 06:43 AM
Not sure if I'll have time today to mess with it. Working on getting the Bolens LK running. Think I'll see about getting new fuel line, plugs and an air filter for it if I go for parts. Also an oil filter.
