Just got my first Bush Hog, a D4-7 from the original owner
d4-7
21 replies to this topic
#16 wpod OFFLINE
wpod
  • 41 Thanks
  • 26 posts
Posted May 03, 2016 - 09:37 AM
Austen- Thanks for the kind words! - Subdude- I can't post pics yet because I'm trying to sort out my deck at the  moment, currently there are no visible tension springs. The Plow is a Brinley #8 ?, and I can't find any ID on the Harrow, but I'll keep looking.. Titus has generously offered to let me come down to his place and check out the layout of the deck and PTO. When I have some good picks, I'll make sure that you get them, Thanks, Paul
  • subdude said thank you
#17 rbooker OFFLINE
rbooker
  • 271 Thanks
  • 134 posts
Posted May 03, 2016 - 03:17 PM
here are pictures of the front pto assembly for the belt drive on my d4-7:
#18 wpod OFFLINE
wpod
  • 41 Thanks
  • 26 posts
Posted May 07, 2016 - 09:12 AM
Great Pics rbooker!, That's exactly what I needed! However, the only part that I do have is the notched rod that goes from the dashboard to the PTO lever. The PTO lever looks easy enough to make, but what do you suggest that I do for an actual PTO Clutch and Pulley ?  I own a couple of Cub Cadets (a 102 and a 122) and the PTO from either of those tractors will fit on the Wisconsin 1 inch shaft. Can anyone suggest a different PTO that might be closer to stock ?,  or perhaps maybe a source for the real deal? Thanks for your help thus far! Paul from Providence.
Edited by wpod, May 07, 2016 - 09:13 AM.
#19 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,364 posts
Posted August 08, 2016 - 08:30 PM
I am doing some research on grill emblems and colors. Did yours have a grill emblem on it? If yes, was it yellow and red or black and red in color?? (or white and red?).
thanks
#20 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted August 10, 2016 - 04:07 AM
   Just looking thru here and noticed your tractor drivetrain is completely different than the v-4-7 I just picked up. mine has the engine going across the frame so the dive pulleys are of the side not in the front.  plus your seat is different , almost like a d-4-10.
        Pete
Edited by petrj6, August 10, 2016 - 04:08 AM.
#21 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted August 10, 2016 - 07:49 AM
        Pete
His tractor is a D4-7 and yours is a V4-7. The engines are mounted differently in those 2 models.
  • Titus said thank you
#22 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted August 10, 2016 - 07:52 AM
        Pete
D= Direct Drive
V= Belt Driven
Also tagged with one or more of these keywords: d4-7
