125 open side ?'s
22 replies to this topic
#16 poncho62 ONLINE
poncho62
  • 1,603 Thanks
  • 1,612 posts
Posted April 23, 2016 - 05:21 PM
Ford LGT 125 cranked but would not start: $500. Not me.
Lots of good stuff with it, a decent deal at $500, I would think
  • ChopRod said thank you
#17 Cat385B OFFLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted April 23, 2016 - 06:56 PM
I was willing to go to $350 on it if it started. I would of gone $500 if the deck was a 50". I's a cheap bassturd, a trait I picked up from this forum. It's a prerequisite if you wanna be a moderator.
#18 poncho62 ONLINE
poncho62
  • 1,603 Thanks
  • 1,612 posts
Posted April 24, 2016 - 06:43 AM
I hear ya on the cheap part.....I picked up this lot last summer for $200....by the time I rebuilt 2 engines, I have about $800 invested, still not too bad.
84BBC3F4-8119-4AA7-865A-A2C0847C53AB_zps
  • jpackard56 said thank you
#19 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted April 24, 2016 - 06:58 PM
The LGT 125 was a hydrostatic.
They all came with hydro lift.
The LGT 100 ( ten horse ) was a standard trans.
That came with a manual lift.
The tractor was worth $350 not running.
The complete set of factory wheel weights was worth close to $350.
The rear PTO and tiller was worth $350.
The 50" deck is worth less than the 42" deck because you can't get blades for it.
The 42" deck would be worth $200 if it was in good shape.
The front blade is of no value.
If it had a set of Ford script hub caps would you have gone $375?
I think I might have gone to $750 on that package.
Joe
  • Cat385B and ChopRod have said thanks
#20 Cat385B OFFLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted April 24, 2016 - 09:16 PM
That's why I stayed home and watched the auction online. I knew I couldn't resist if I was there in person.
If it had the two stage blower instead of the blade, then I would of gone whatever it took to get it. Hubcaps would of made no difference to me.
  • Rock farmer said thank you
#21 poncho62 ONLINE
poncho62
  • 1,603 Thanks
  • 1,612 posts
Posted April 25, 2016 - 05:17 AM
Joe
Sorry to disagree......I own 2 125s with hydro trans and manual lift...here is one
You could also get a 120 (12hp with std trans and manual lift)....I have never seen one of those
E281122A-1762-44B3-897D-CA9F66D0582F_zps
Edited by poncho62, April 25, 2016 - 05:25 AM.
  • skyrydr2 and Rock farmer have said thanks
#22 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted April 25, 2016 - 07:17 AM
Yup ! The 125s ALL CAME FACTORY WITH MANUAL LIFT! The hydraulic lift was an option that was pretty $$ for the 125's. And you were better off buying the 145 as it had more power too. This was standard for all the LGT series up to the end of the Jake made units. The handles had to be removed for them to work safely , and a cover plate installed. This is what made this option so $$$
#23 ChopRod OFFLINE
ChopRod
  • 52 Thanks
  • 72 posts
Posted May 15, 2016 - 09:48 PM
Actually its an LGT 165 under the disguise of a 125. Larger air cleaner and exhaust pipe. Well worth $750. Agree with you Rock Farmer on values.
