? Carb/fuel pump inlet ?
5 replies to this topic
#1 jpackard56 OFFLINE
jpackard56
  • 1838 Thanks
  • 1434 posts
Posted April 22, 2016 - 07:31 AM
So this inlet tube just pulled out of fuel pump when trying to remove the old fuel line. Doesn't look like it was soldered ? Whats supposed to hold this in there to keep from leaking? I haven't downloaded manuals yet (eyes are not working that good today) they may talk about this, not sure.
  • Auburn David and luzpr11 have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted April 22, 2016 - 08:11 AM
most are just pressed in..I have used a punch to expand them back out(not much) when they get loose like that and press them back in with no issues.
  • jpackard56 said thank you
#3 boyscout862 ONLINE
  • 14844 Thanks
  • 9895 posts
Posted April 22, 2016 - 08:13 AM
I've run up against the same thing a few times. They just seem to be pressed in and it doesn't seem to take much to press in or pull out. I searched through my carb parts and found two other types of push in fittings for carbs or fuel pumps. The last one was 4 years ago on a B&S 11hp vert shaft in my JD 111. It has worked fine for 4 summers now. I was tempted to put epoxy on it when assembling the fuel pump but I was afraid that it might split the casting. Good Luck, Rick
#4 MiCarl ONLINE
MiCarl
  • 2591 Thanks
  • 1302 posts
Posted April 22, 2016 - 11:28 AM
We frequently pull them out of motorcycle fuel taps.  Always just tap them back in.  Never had a problem.
#5 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted April 22, 2016 - 05:18 PM
They are pressed in like the others mentioned
#6 jpackard56 OFFLINE
jpackard56
  • 1838 Thanks
  • 1434 posts
Posted April 23, 2016 - 07:46 AM
I'm sure delicate is the password, not sure I'm qualified with my eyes....Is it a standard tapered punch or one you have adjusted for this purpose ?
Any thoughts about using something like "Seal-all" (the gas tank repair in a tube) ? It leaks fuel currently when installed.
