Todays surprise | 1957 Wonderboy 450.
22 replies to this topic
#16 wbakunis OFFLINE
wbakunis
  • 220 Thanks
  • 191 posts
Posted April 21, 2016 - 03:19 PM
Ditto!  That's one of the nicer WB's I've seen.
Stuck valve?  Did you pop the head and peek?  Very common.
I only pulled the breather cover to look. The valves appeared to be moving fine. Ill take the head off once I get a replacement gasket.
#17 wbakunis OFFLINE
wbakunis
  • 220 Thanks
  • 191 posts
Posted May 03, 2016 - 12:47 PM
Cleaned the wonderboy gas tank. So much rust removed yet the tank is still in good shape.
20160503_104105.jpg 20160503_104115.jpg 20160503_104123.jpg 20160503_104142.jpg 20160503_104149.jpg
  • Gtractor said thank you
#18 wbakunis OFFLINE
wbakunis
  • 220 Thanks
  • 191 posts
Posted September 29, 2016 - 06:26 PM
I've started working on the wonderboy again. Tore most of the motor & gear box down. Still need to check all the pullies and clean them.
Does anyone have experience with these wonderboys? The high/low range isn't shifting right. Seems like an excessive gap between the diff and gearbox.
#19 CraftsmanGT ONLINE
CraftsmanGT
  • 228 Thanks
  • 268 posts
Posted October 03, 2016 - 07:51 PM
14XXXX model B&S should be 6hp.
  • wbakunis said thank you
#20 jabelman OFFLINE
jabelman
  • 2,247 Thanks
  • 1,609 posts
Posted October 03, 2016 - 08:19 PM
did you cut the tires off?
#21 wbakunis OFFLINE
wbakunis
  • 220 Thanks
  • 191 posts
Posted October 03, 2016 - 09:25 PM
The one tire I did. It was already ripped open and the tube was escaping out haha. You can see it in this picture20160420_152544.jpg
#22 wbakunis OFFLINE
wbakunis
  • 220 Thanks
  • 191 posts
Posted October 03, 2016 - 09:32 PM
oh wow. I'm even more confused now with this wonderboy. This means the motor is not original? According to a manual I found for this wonderboy, someone wrote down B&S Engine 141300. On SimpleTractors, it shows this wonderboy as 4hp.
http://gardentractor...service-manual/
Edited by wbakunis, October 03, 2016 - 09:34 PM.
#23 jabelman OFFLINE
jabelman
  • 2,247 Thanks
  • 1,609 posts
Posted October 04, 2016 - 05:11 AM
I would think that engine is original to it. the time era matches, I have some literature on these I will look tonight
