NAPA fuel pump.
9 replies to this topic
#1 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted April 19, 2016 - 08:42 PM
Here's pix of pump I got today for Kohler single. What think?
  • wvbuzzmaster, shorty, Georgejen and 1 other said thanks
#2 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,107 Thanks
  • 4,881 posts
Posted April 19, 2016 - 09:00 PM
I think your float is gonna be overwhelmed.
#3 DougT OFFLINE
DougT
    Dog Approved
  • 6,847 Thanks
  • 4,949 posts
Posted April 19, 2016 - 09:05 PM
All depends what it is regulated at. Says on the package it is designed to replace oem pumps. It should work.
#4 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted April 19, 2016 - 11:01 PM
If it is over 3 PSI your carb will be running over.  1-2 PSI is the spec you need.
  • Gtractor, Alc, HDWildBill and 1 other said thanks
#5 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted April 20, 2016 - 04:27 AM
Says 1 to 4, but how does it regulate? These things shut down or bypass or what when not needing flow?
#6 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 20, 2016 - 09:21 AM
I think you will be OK Grump.  1-4 PSI should do the trick, just make sure you connect it to a 12 volt source.  If it proves to be a bit much then just lower the voltage or make the fuel line longer.
#7 MiCarl OFFLINE
MiCarl
  • 1,910 Thanks
  • 1,019 posts
Posted April 20, 2016 - 11:21 AM
That looks just like the one I have.  I don't think it regulates because it runs continuously.
I suspect it's just a vane pump and when the pressure gets high enough (presumably 4psi) it just leaks around the vane.
#8 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted April 23, 2016 - 07:47 PM
Put pump in tonight. Tried starting on fluid first, only ran when sprayed. After pump was in, starts right up now. I mounted it in bottom of hood and lines to it easy and still opens no issues. I ran juice off coil feed. Only on when key on, why not? Vibes a bit at first, but don't hear once running. Drove around some and don't see leaks. Originall still in block, need a plate for that. Anyone here sell, w/gasket?
  • ducky and HDWildBill have said thanks
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 24, 2016 - 08:44 AM
Thanks for the feedback GG.  Glad you got it working and hopefully it will last a very long time.
#10 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted April 26, 2016 - 10:31 AM
I think you will be happy with the electric pump.  Carb is always full at start up.
