skinny little belts
1 reply to this topic
#1 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted April 19, 2016 - 04:48 PM
I have a Gilson rear engine rider that I want to put a 12 HP engine on to replace the 8 HP that was on it. Bolting the engine on is not a problem but one thing has me wondering. I think the crankshaft is bigger on the 12 so I will have to use different pulleys . Still not a problem , but I the Peerless 5 speed transmission has a pulley on it for a narrow belt. 3L maybe? I wonder if the drive belt was a narrow belt for a reason , or can I convert to a wider ( 4L) belt that I have already, or can easily get pulleys for? Clearance is not a factor.
  • clariceat60 said thank you
#2 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 19, 2016 - 06:10 PM
I can't think of a reason not to go with the 4L belt and pulleys.
If I where you, I'd go for it.
  • old coot said thank you
