Battery life in GT's
16 replies to this topic
#1 lrhredjb ONLINE
lrhredjb
  • 417 Thanks
  • 382 posts
Posted April 19, 2016 - 04:46 PM
How long does your battery last in your GT? I had been buying one about every 2 1/2 yrs until the last one I got
I just topped off the charge after returning from 6 mo. vacation and the voltage shows 12.5. The date sticker on it
shows April 2009. I never had a battery last anywhere near this long before. It's an Exide brand BTW.
  • wvbuzzmaster, boyscout862, antonioco18 and 1 other said thanks
#2 Bolens 1000 ONLINE
  • 13,728 Thanks
  • 17,635 posts
Posted April 19, 2016 - 04:49 PM
I have some from 2008 Going still , I generally get 5-7 years out of them but have always bought the good ones , Decka , interstate, B&S ect. Napa specials only last a few years at best. I also think the more CCA battery you get the longer the life as well
  • boyscout862 and propane1 have said thanks
#3 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted April 19, 2016 - 05:05 PM
Lawn and garden battery lasts 3-4 years tops for me. I try to upgrade to car batteries when they fit.
  • limebuzz, IamSherwood, boyscout862 and 1 other said thanks
#4 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted April 19, 2016 - 05:52 PM
I buy the ones for electric scooters..they are deep cycle and last forever.
#5 IamSherwood OFFLINE
  • 8,384 Thanks
Posted April 19, 2016 - 06:00 PM
I couldn't agree with you more.
  • wvbuzzmaster and boyscout862 have said thanks
#6 DH1 OFFLINE
DH1
    Electric Tractors
  • 4,890 Thanks
  • 5,417 posts
Posted April 19, 2016 - 06:08 PM
:iagree:  :ditto:
#7 MiCarl ONLINE
MiCarl
  • 1,516 Thanks
  • 807 posts
Posted April 19, 2016 - 06:19 PM
Last summer my Craftsman lawn tractor turned 18 years old and the 2nd battery failed.  That's 9 years per battery.
I've found if you keep the cells topped up and throw a battery maintainer on when it'll be parked for awhile I get a lot of life from them.  Of course if the charging system isn't working properly it can kill them real quick.
Edited by MiCarl, April 19, 2016 - 06:21 PM.
#8 Eric OFFLINE
Eric
  • 1,200 Thanks
  • 750 posts
Posted April 19, 2016 - 07:31 PM
The more CCA the longer they last is not true unless dealing with lithium or such, standard batteries need more plates to create more amps in the same size case. This means that they break down faster due to degradation of the internal components. Was reading about this recently and there is an equation that slips my mind at the moment that states the actual time it takes for the plates to degrade under normal use and when adding amps how much faster this process happens per certain amount of said amps. Sorry just a bit of useless knowledge I semi retained lately.
  • Bolens 1000, wvbuzzmaster and jpackard56 have said thanks
#9 Tecumseh power OFFLINE
Tecumseh power
  • 1,369 Thanks
  • 1,041 posts
Posted April 19, 2016 - 08:14 PM
Napa has them on sale for 16.99 right now just got one. Has a 6 month warranty
  • wvbuzzmaster and jpswift1 have said thanks
#10 jpswift1 OFFLINE
jpswift1
  • 359 Thanks
  • 343 posts
Posted April 19, 2016 - 08:31 PM
Can you post a link for this deal please?  I only see them for $23.99.
  • Tecumseh power said thank you
#11 toppop52 ONLINE
toppop52
  • 4,295 Thanks
  • 4,051 posts
Posted April 19, 2016 - 08:40 PM
The biggest killer is letting a battery get really low then having it freeze.
#12 Tecumseh power OFFLINE
Tecumseh power
  • 1,369 Thanks
  • 1,041 posts
Posted April 19, 2016 - 09:14 PM
In Store Here In PA Anyways All Of Them Are 16.99 They Had Signs Up Along The Highway That's How I Knew. It's probably nationwide. The slip said regular 43.99. They have two different CCA. It's the lower one but it turns my 20 horse fine
  • jpswift1 said thank you
#13 jpswift1 OFFLINE
jpswift1
  • 359 Thanks
  • 343 posts
Posted April 19, 2016 - 09:24 PM
Cool, thank you.  I'll have to take a look.
#14 Sawdust OFFLINE
Sawdust
  • 4,945 Thanks
  • 3,022 posts
Posted April 19, 2016 - 10:55 PM
My local Napa told me their batteries are made by Exide & so are the ones at TSC.
  • jpackard56 said thank you
#15 TAHOE ONLINE
TAHOE
  • 7,315 Thanks
  • 5,359 posts
Posted April 20, 2016 - 06:50 AM
Mine vary. I had one just die last year, it went about 7 yrs. just replaced the one in our church LT, it only lasted 2 yrs. As stated, keep the fluid levels up and keep them charged will make them last longer. The one in our church mower went dead over both winters, that's the worst thing for them is to let them go completely dead.
