What is it? T92 transmission and?
12 replies to this topic
#1 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,798 posts
Posted April 18, 2016 - 04:32 PM
Just picked this up from a tractor buddy of mine. Its definitely a t92, and appears to be a Crosley or B/W varient??
I haven't messed with it other then making sure the output wasnt sloppy, and main trans shifted.
He had told me it came with a clutch over the phone, but after getting it im thinking its a 2 speed however, im not sure what it is? I would think an aux box would be on the output side, but this unit is definitely on the input side, and appears to be cast aluminum with a keyed input shaft.
Ok transmission gurus, what is this unit on the input side of the 92?
Edited by stiemmy, April 18, 2016 - 04:56 PM.
  • classic and reneeic1 have said thanks
#2 classic ONLINE
classic
  • 4,677 Thanks
  • 2,061 posts
Posted April 18, 2016 - 06:41 PM
Looks like it might be a wet PTO clutch. You should drain it and pull the side cover.
  • stiemmy said thank you
#3 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,798 posts
Posted April 18, 2016 - 07:05 PM
Im actually hoping you are correct.
Your right, I should pull a plate. Maybe after work tomorrow Ill have a lil time to look at it. If I get to it, Ill post some pictures.
#4 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted April 18, 2016 - 07:11 PM
Third gear is direct drive so you could count turns to see if there is any reduction or increase.Pretty interesting piece.
#5 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,798 posts
Posted April 18, 2016 - 08:02 PM
Correct, Ill try and check it out.
Yes it is unusual for sure, cant find anything on it!
As stated earlier, I hope Classic is right about it being a clutch, but I aint never seen 1 of these.
If it is a clutch, I might have a use for it. Im also going to have to find a female splined shaft, or yoke for the output side.
#6 glgrumpy OFFLINE
  • 8,120 Thanks
  • 7,555 posts
Posted April 19, 2016 - 08:28 AM
Wonder what input shaft the trans has?  Some had short one with no clutch option and just used a gear there or pulleys like on Speedex and others. Have no idea on the other case. Looks like a big engagement lever and is that a LOCK tin that drops over the moving shaft then to lock into place?  That is also ONE beefy shifter shaft coming from the trans, but short. I think his  is an item you set trans speed and then interlock other to operate what-ever and not really made for shifting on the go and such, like on a tractor. Must be some sort of machinery drive, like a bailer  or road work machine or such?
#7 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,798 posts
Posted April 19, 2016 - 04:41 PM
Well folks, the wait is over. It is........in 3, 2, 1, a wet clutch.
I stopped at a buddies shop today, and pulled a side cover to have a look see, and took a couple pics.
This having a clutch is actually good news as i wanted this transmission for my Bolens 600, cause I think that one is going under the knife anyway.
I still dont know what it is from, but I think it will work.
Thanks for all the imput guys, Cheers!
  • Alc, Username and Auburn David have said thanks
#8 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted April 19, 2016 - 04:55 PM
Might be military.I bought a whole pallet of surplus T-92 transmissions with a different shifter on them.
  • Alc and stiemmy have said thanks
#9 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,798 posts
Posted April 19, 2016 - 05:09 PM
Its possible, or like Grumpy kind of thought maybe a bailer, or something.
Edited by stiemmy, April 19, 2016 - 05:16 PM.
#10 glgrumpy OFFLINE
  • 8,120 Thanks
  • 7,555 posts
Posted April 19, 2016 - 07:17 PM
OK, guess I don't get what a WET clutch is or how it works. Some cones that slide together?  Must be some way to go from stop to start w/out instant lock-up. Don't know what it is.
#11 MiCarl ONLINE
MiCarl
  • 1,647 Thanks
  • 884 posts
Posted April 19, 2016 - 07:42 PM
A wet clutch is similar to a dry clutch except it runs in oil.  If your car has an automatic transmission it has several wet clutches.
On a motorcycle (and I expect most wet clutches) there are multiple clutch plates stacked together around a central shaft.  Every other plate is splined to the central shaft.  The other plates are splined to a basket around the assembly.  When the pressure plate compresses the stack the central shaft is locked to the basket.
Here is a picture of motorcycle clutch plates: 71-110.jpg
The basket in turn is connected to another shaft.
On motorcycles the outer basket is connected to the crankshaft by either a ring gear or chain.  The center shaft is the input shaft to the transmission.
But on a motorcycle the input and output shafts are on the same side.  The clutch pictured has the output opposite the input.  I suspect in that case the basked itself is splined directly to the shaft.
I suspect the clutch on the T-92 is more like this one for a Kubota tractor: wetclutchpack.jpg
Edited by MiCarl, April 19, 2016 - 07:48 PM.
#12 glgrumpy OFFLINE
  • 8,120 Thanks
  • 7,555 posts
Posted April 19, 2016 - 08:39 PM
Yep, aware of bike clutch, just wasn't getting that thought with pictures.
#13 stiemmy ONLINE
stiemmy
  • 2,452 Thanks
  • 1,798 posts
Posted April 20, 2016 - 07:58 AM
Nice thing is, I could put this on just about anything.
Not to steer off topic, but I have been looking at PTO yokes, and seems that getting something to fit shouldn't be a problem.
