Mower deck gearbox
3 replies to this topic
#1 PapsGT17 OFFLINE
PapsGT17
  • 28 Thanks
  • 17 posts
Posted April 18, 2016 - 10:37 AM
Anyone know what the torque specs or gear backlash should be on the gearbox on the mower deck. I'm rebuilding the box on my 831012 48" deck. I have the original manual for the deck but it only gives a parts breakdown and instructions on setting level and replacing the belt. I need to know the torque for the nut on the output shaft and setting for gear lash.
  • tonyqo69 and samanthaau18 have said thanks
#2 PapsGT17 OFFLINE
PapsGT17
  • 28 Thanks
  • 17 posts
Posted April 18, 2016 - 12:52 PM
Answered my own question. Found all the info in the attachment section of the repair manual for the tractor.
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,530 Thanks
  • 9,825 posts
Posted April 18, 2016 - 01:06 PM
What was the torque setting and the gear lash spec?
#4 PapsGT17 OFFLINE
PapsGT17
  • 28 Thanks
  • 17 posts
Posted April 18, 2016 - 01:51 PM
Torque on the nut on output shaft inside the gearbox is 50 ft.lbs. Spindle nut holding blade and pulley on is 50-60ft.lbs. End play on output shaft should be .003-.008in with DRY bearings. Backlash for gears is .005-.015in.  End play on input shaft is .003-.008in as well.
  • Cat385B said thank you
