Tiller power plant
4 replies to this topic
#1 greenb69 OFFLINE
greenb69
  • 270 Thanks
  • 210 posts
Posted April 18, 2016 - 10:23 AM
I have a 5 horse briggs gear reduction motor that has been sitting on the shelf. First question is, can I remove the gear reduction and use it as a straight shaft. Second, would it be enough to run a 36 inch tiller made to run off the back of a gt. This is the tiller I am wanting to use it on.
Sent from my SCH-I545 using Tapatalk
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted April 18, 2016 - 10:35 AM
Most likely, a crankshaft change would be needed.
Most of the B&S gear reduction engines had a short crankshaft with gear teeth machined into the end of the crank.
#3 dodge trucker ONLINE
dodge trucker
  • 2,404 Thanks
  • 3,100 posts
Posted April 18, 2016 - 12:37 PM
5hp for a 3' tiller gets a "doubtful" vote from me unless it is recently tilled with a heavier duty unit, especially if it's clay soil.
#4 greenb69 OFFLINE
greenb69
  • 270 Thanks
  • 210 posts
Posted April 18, 2016 - 01:37 PM
Thanks to you both. I kind of figured it would be a reach. I will either find a larger engine or hook up the pto shaft on my powerking.
#5 sharkman OFFLINE
sharkman
  • 358 Thanks
  • 283 posts
Posted April 18, 2016 - 01:53 PM
most self-powered pull behind tillers are 36" and run a 8 hp on them
