Finally have a big project done at work (sprayer boom)
8 replies to this topic
#1 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 17, 2016 - 09:01 PM
I figured some of you guys would enjoy this.
A year and 4 months ago the boss came up to me and said "Nate, I have a special project for you". When he says that I know its not going to be a fun job. He was toying with the idea of expanding the width of the sprayer from 100' to 132' so you can drive in the planter tracks. Its so much stabler and easier to control if your driving on previous tracks, not to mention less time in the field. The reason for making one is he figured one could be made cheaper than buying one.
After planning, discussing and many sleepless night I started to piece things together. Hit many bumps and issues along the way but we figured them out. 2 weeks ago I got to start hanging the booms and more issues. Spent the last ten or so days living at the shop fixing and fabing to make things work like they should. Glad its finally on and working. Still a couple things to work out but its fictional at least. I think we did alright money wise but the knowledge we gained is priceless.
I was tickled pink watching this thing go across the field. Its crazy how quick it is now. Sprayed a 106 acre field in about half an hour!
IMG_20150511_112334_877.jpg IMG_20150511_112420_720.jpg IMG_20160407_171126_611.jpg IMG_20160412_224652_963.jpg IMG_20160415_191801_131.jpg IMG_20160417_184704_270.jpg
  • wilberj, jdslednut, limebuzz and 9 others have said thanks
#2 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted April 17, 2016 - 09:08 PM
Looks great. Good Luck, Rick
  • Nato77 said thank you
#3 wilberj ONLINE
wilberj
  • 5,097 Thanks
  • 5,625 posts
Posted April 17, 2016 - 09:15 PM
Great work Nate!
  • 14,889 Thanks
  • 15,514 posts
Posted April 17, 2016 - 09:22 PM
Great job Nate, did you build the booms out of Aluminum?
#5 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 17, 2016 - 11:21 PM
Yup all aluminum except the hinge points. If I had the inventory that a steel house has would've used aluminum. With making them out of aluminum they weigh a little less than the 100' steel ones.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 18, 2016 - 10:48 AM
That is impressive!  Saturday I watched a neighbor plant corn and then spray  a large field. He was in and out before 11:00 am.
Amazing what can be done with big equipment.
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,877 Thanks
  • 6,358 posts
Posted April 19, 2016 - 01:24 PM
If you get enough speed up, you might able to take off!
#8 MH81 OFFLINE
  • 29,979 Thanks
Posted April 19, 2016 - 05:24 PM
Nice job and neat retrofit.
Did you have to replac the pump and everything also or was it big enough?
#9 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 19, 2016 - 11:22 PM
So far the pump is big enough. He not driving as fast as he did with the smaller one though. We cranked it up to 100psi and I did just fine
