782 repower KT17 to M18 wiring help needed
11 replies to this topic
#1 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted April 17, 2016 - 04:02 PM
Repowered a 782 with a M18. How do I wire this to work properly.
#2 CRFarnsworth ONLINE
CRFarnsworth
  • 4,949 Thanks
  • 2,205 posts
Posted April 17, 2016 - 04:19 PM
Did you have a donor tractor or just the engine?
If you have the donor tractor swap the entire harness and electrical.  I recently went that route swapping the engine from a 1810 into a 782.
If you just had the engine and the wiring hook up is different then I can't be much help at this point.
Let me go look at my kt 17 and compare to the m18.  I'll also check for a schematic.   Rick
#3 CRFarnsworth ONLINE
CRFarnsworth
  • 4,949 Thanks
  • 2,205 posts
Posted April 17, 2016 - 04:37 PM
Found a couple schematics.
MyKT17 has two black wires at plug in for the engine. One went to the coil ( on top of the engine) the other went to a module (voltage regulator) mounted on the shroud.
The M18 had a green wire that went to the oil pressure unit, a black wire that went to the module (voltage regulator), and a white wire that went to the coil, or magneto  (inside the shroud).  Hope this helps.  Rick
Edited by CRFarnsworth, April 17, 2016 - 05:50 PM.
  • ducky and BNK have said thanks
#4 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted April 17, 2016 - 04:53 PM
I am trying to use the 782 wiring. The 1811 it came out of wasn't wired correctly and was a wiring hack job. I was told I need a relay, I am trying to figure out what I need to make this engine run and charge like it should
#5 glgrumpy OFFLINE
  • 8,704 Thanks
  • 7,971 posts
Posted April 17, 2016 - 05:06 PM
Isn't KT17 Battery ignition with coil and the M18 was Magneto, no points and coil?   Thought that was major diff?  That would need a diff key then too?  Maybe this is too knew and has much more wiring than I'm thinking.
#6 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted April 17, 2016 - 05:27 PM
I just had a discussion with a guy on Facebook. He is a repower guru.
I will post when I get it wired
#7 KennyP OFFLINE
  • 40,023 Thanks
  • 46,722 posts
Posted April 17, 2016 - 06:06 PM
Which of those are for a Magnum 18? When I put the M18 in Alice, I used the wiring diagram in the owners manual for it.
#8 CRFarnsworth ONLINE
CRFarnsworth
  • 4,949 Thanks
  • 2,205 posts
Posted April 17, 2016 - 09:16 PM
None of the info I found told which engine.  It only showed above and below a certain serial number for each model.
The first four are 782 , the last two are 1811.
I once swapped an m18 from a 682 to a 782 and changed the harness with it because they were different .
Edited by CRFarnsworth, April 17, 2016 - 09:21 PM.
#9 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted April 18, 2016 - 04:02 AM
You either need to install a relay or use a different ignition switch. An Internet search should take you to a couple different examples on how to add in the relay. I'm at work otherwise I would post a pic of the wires rerouted through the relay.
Edited by aagitch, April 18, 2016 - 04:06 AM.
#10 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted April 19, 2016 - 11:41 AM
I have the relay installed, I am waiting for the correct keyswitch. I know the m18 ran, and only has 27hrs. But the Walboro WNG carb sucks so I want to get a new carb
#11 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted April 19, 2016 - 04:57 PM
27hr mag? NICE!
#12 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted April 19, 2016 - 05:28 PM
Built in 1997. One of the last built M18s from what kohler said
