Sears ss16 yard sale find
32 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 975 Thanks
  • 742 posts
Posted April 16, 2016 - 09:37 PM
Hi everybody, i thought i would share my find today. Its in good shape, came with a nice mower deck.the thing cost me 75.00. Bad part, it doesnt have spark and it needs a seat
Edited by Xrperry, April 16, 2016 - 09:37 PM.
  • Gtractor, MH81, KennyP and 4 others have said thanks
#2 glgrumpy ONLINE
  • 8,505 Thanks
  • 7,857 posts
Posted April 16, 2016 - 09:51 PM
Well, not the Tec engine with bad ignition module at least.  I bet points cleaning and new plugs might make difference on an Onan??
  • MH81, Lmiller3358 and Xrperry have said thanks
#3 Xrperry ONLINE
Xrperry
  • 975 Thanks
  • 742 posts
Posted April 16, 2016 - 09:59 PM
Yes it has a BF onan, also a onan sticker under the hood saying it has been short blocked. Dont know when that happened
#4 EricFromPa OFFLINE
EricFromPa
  • 3,392 Thanks
  • 3,018 posts
Posted April 16, 2016 - 10:45 PM
That's a good buy there.The top grill pieces are selling for ridicules money if not cracked or broken.What dash is on that one?Plastic or aluminum?  I see the Metal gas tank so it's a fairly early one.
Clean the points if still no spark stick another Condenser in her.
Edited by EricFromPa, April 16, 2016 - 10:49 PM.
  • Lmiller3358, Sawdust and Xrperry have said thanks
#5 Xrperry ONLINE
Xrperry
  • 975 Thanks
  • 742 posts
Posted April 16, 2016 - 11:19 PM
Its a plastic dash. Good thing is there isnt a crack on anything. Thanks for advice,it could turn out to be a lot of checking
#6 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted April 17, 2016 - 04:38 AM
Good looking tractor!
  • Xrperry said thank you
#7 Lmiller3358 OFFLINE
Lmiller3358
  • 1,466 Thanks
  • 1,412 posts
Posted April 17, 2016 - 06:31 AM
Great deal, good luck with it !
#8 Sawdust OFFLINE
Sawdust
  • 5,472 Thanks
  • 3,297 posts
Posted April 17, 2016 - 07:57 AM
That's a nice one looks well kept. Congrats
#9 MNGB ONLINE
MNGB
  • 1,852 Thanks
  • 1,285 posts
Posted April 17, 2016 - 11:32 AM
You done good for that money one couldn't pass that up, as posted check the points condenser and the ignition switch if still nothing then it could be the coil they do go bad on the Oman's, if that's the case there are a number of coil replacements that have been done using a GM dual coil.
#10 Xrperry ONLINE
Xrperry
  • 975 Thanks
  • 742 posts
Posted April 17, 2016 - 12:22 PM
Thanks mngb, it will be a fun and i bet educational project. I have been looking for one of these for a long time, and to see one in a yard sale for 75 i about soiled myself .lol
  • EricFromPa and MNGB have said thanks
#11 KC9KAS ONLINE
KC9KAS
  • 5,268 Thanks
  • 4,644 posts
Posted April 17, 2016 - 03:03 PM
I would say you did good for $75!
#12 Mtypython OFFLINE
Mtypython
  • 331 Thanks
  • 336 posts
Posted April 17, 2016 - 07:44 PM
Nice find
#13 JiminRI OFFLINE
JiminRI
  • 84 Thanks
  • 80 posts
Posted April 17, 2016 - 08:01 PM
I'd say you got the deal of the year - a real steal. I wish I had gone to that yard sale first.
All good advice on points, condenser and coil. If you do get to testing the coil you can use the procedure below that I found a while back.
Good luck with it.
JiminRI
Coil Test
While the engine is cold, remove all wires from the coil. Set your meter to ohms and test across the primary winding (the small posts). It should read 3.87 - 4.83 ohms. Now test across the secondary winding (the spark plug wire posts). It should read 12,660 - 15,400 ohms. If they fall much out of this range, the coil is bad.
If you get it running and it seems to fail when hot, retest the coil as above and see how the readings compare.
  • MH81, jpackard56, Xrperry and 1 other said thanks
#14 Xrperry ONLINE
Xrperry
  • 975 Thanks
  • 742 posts
Posted April 17, 2016 - 09:54 PM
Thanks jiminri, since it is stored in the warehouse at work, i have room to work and a full outfitted metal shop,and electrical test equipment. I can work on it before work in the morning,at noon,after work,and on the weekend.its going to give my homelite t8 and old 1960s craftsman 8hp someone to talk to.lol
#15 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted April 18, 2016 - 07:22 AM
you stole it.
As stated, that unbroken grill is going for 150-300 by itself.
