How do you keep garden tools from rusting?
27 replies to this topic
#16 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted June 05, 2011 - 01:51 PM
hello , i use an used oil .
Welcome to GT Talk. Trying to figure out where you are.
#17 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted June 05, 2011 - 02:26 PM
I seem to store my plows different every year, this year they are ALL outide in a shed addition sittiong on roofing shingle scrap to keep them off the dirt lol. And no, I did not clean, oil, lube, or paint them either. I need to locate a place (after the Caterpillar is working again) so turn turn all day long and shine all my plows so I can store them properly.
#18 grnspot110 OFFLINE
grnspot110
  • 4,296 Thanks
  • 2,685 posts
Posted June 05, 2011 - 04:58 PM
It was always my job to grease everything with old gun grease as a boy (long time ago)! :(
I tried the 'waxy' plow coat for a while, didn't like it. Now I use the cheapest flat black spray paint I can find, flat black seems to come off easier when I start plowing again. ~~ grnspot
#19 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,676 Thanks
  • 5,052 posts
Posted June 05, 2011 - 09:40 PM
[quote name='grnspot110']It was always my job to grease everything with old gun grease as a boy (long time ago)! :(
LG, I guess I always just figured the moldboards were made of wood and you stored them in your cave when you were young.
:bigrofl: :poke: :smile1:
#20 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted June 12, 2011 - 06:57 AM
[quote name='Gtractor'][quote name='grnspot110']It was always my job to grease everything with old gun grease as a boy (long time ago)! :(
:bigrofl: :poke: :smile1:[/QUOTE]
That's why he spends so much time in the man cave. Old habits are hard to break.
#21 grnspot110 OFFLINE
grnspot110
  • 4,296 Thanks
  • 2,685 posts
Posted June 12, 2011 - 07:34 AM
Close, but not quite that old, just feel like it most of the time! :D
#22 Dirtdoc OFFLINE
Dirtdoc
  • 12 Thanks
  • 15 posts
Posted July 16, 2011 - 10:57 PM
I use soft black paint. It stays on for years and comes off very quickly in the soil. It has no hardener it which is why it comes off quickly....Greg
#23 rbhoover OFFLINE
rbhoover
  • 10 posts
Posted August 10, 2011 - 08:04 PM
On the farm we used old oil sprayed out of a cheapo spray gun (use a large tip 2.2mm) bought from Harbor Freight... works pretty well!
#24 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted August 11, 2011 - 08:08 PM
I hava a couple pails of sand, and after i change the oil in one of my garden tractors i just dump it in there, mix it up and leave it there till spring.I've done that for years.
#25 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted December 11, 2011 - 01:17 PM
I use Slip-plate or some other graphite based paint on my plow. It lasts forever & dirt
doesn't stick unless it is too wet.
#26 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted December 19, 2011 - 11:33 AM
Depends on where it is going to be stored.
Stuff that will be out of the elements (inside or under cover) usually just spray with PB Blaster or WD40, or similar.
If it is gonna be out in the weather, cheap spray paint for blades and stuff that is gonna be polished clean when I use it again, or "real paint" (touchup) for those surfaces that the paint normally doesn't get worn off of. For example, I usually pressure clean and paint the underside of my mower decks before putting them away for the winter...
I usually keep matching color spray paint around for my equipment. If I have an "incident" (scratch the tractor or something that usually has paint on it), will do a quick coverup to protect the booboo from rust at the end of the day, then when I get a chance (after a few "incidents"), will get out the touchup gun and put a good coat of paint on it.
#27 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted December 24, 2011 - 12:51 AM
Depends. I like air tool oil for a lot of applications because it's light and won't damage rubber and plastic components. For things likely to be in contact with the ground, I use canola oil because it's bio-degradable and I really don't want fossil fuel residue on my veggies.
#28 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted December 30, 2011 - 09:48 PM
I don't personally do it, but an Uncle of mine used beeswax. Of course, he was a beekeeper and had tons of it around, heat it up and brush it on. Myself, I keep the implements in a shed over the winter and what little surface rust appears goes away in a couple passes. Couple more passes and the plow shines like a mirror.
