New member, MW simm 1271
18 replies to this topic
#1 Paulsadog OFFLINE
Paulsadog
  • 7 Thanks
  • 10 posts
Posted April 14, 2016 - 08:37 PM
Hi all. Recently bought a MW Power-trac 7hp tractor. Belive it's a Simplicity model VC. Working thru some carburetor issues and waiting for a wire crimper for the spark plug connector to come in the mail.
I'll be asking for some advice on working on the axel but for now I'll try to post some pictures.20160326_164159.jpg 20160326_164615.jpg
Edited by Paulsadog, April 14, 2016 - 09:02 PM.
  • Alc, Bruce Dorsi, jpackard56 and 4 others have said thanks
#2 DougT ONLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Posted April 14, 2016 - 08:42 PM
Welcome to the forum. Not sure what happened with the pictures. you can find some info that may help here:  http://gardentractor...-how-to-videos/
  • Paulsadog said thank you
#3 hbryant123 OFFLINE
hbryant123
  • 6 Thanks
  • 14 posts
Posted April 14, 2016 - 08:52 PM
Welcome! I am new as well! I've got an old 5 hp Midland!
#4 hbryant123 OFFLINE
hbryant123
  • 6 Thanks
  • 14 posts
Posted April 14, 2016 - 08:53 PM
My engine is like yours in design! What issues is it having?
#5 Paulsadog OFFLINE
Paulsadog
  • 7 Thanks
  • 10 posts
Posted April 14, 2016 - 08:56 PM
Thanks,
Pretty neat these older machines. Looking forward to the local tractor show so can see about locating a few parts.
#6 Paulsadog OFFLINE
Paulsadog
  • 7 Thanks
  • 10 posts
Posted April 14, 2016 - 09:01 PM
According to the manual I have there looks to be a bushing, washer than a retaining ring inside the axle tube/housing. I have yet to clean up the axle for a better look and pictures but it seems like the retaining ring has been pushed out towards the tire and is rather worn.
Duh, you meant issues with the engine. Just had to clean out the old gas which gummed up the float valve. Replace some gaskets and cleaned out the jets. Just need to fix the spark plug wire then try to run it again.
Edited by Paulsadog, April 14, 2016 - 09:13 PM.
#7 Paulsadog OFFLINE
Paulsadog
  • 7 Thanks
  • 10 posts
Posted April 14, 2016 - 09:07 PM
Thank, think I'm getting the hang of adding the pictures. Tried to watch the video in the link, it played in VERY slow motion. Don't know if it's my devise on the android operating system or not?
#8 DougT ONLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Posted April 14, 2016 - 09:22 PM
Down at the very bottom of the main forum pages on the left there is an option to change themes. There is a mobile option. Are you using that? I don't have a smart phone so can't be much help there. you could do a search in the site suggestions and questions forum for something that might help.
#9 hbryant123 OFFLINE
hbryant123
  • 6 Thanks
  • 14 posts
Posted April 14, 2016 - 10:18 PM
Yea it sounds like your axle is a little different than mine, so far i havnt messed with my carb any i have been wondering what the procedure is for adjusting it, my spark plug wire does not have a boot on it!
#10 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted April 14, 2016 - 11:07 PM
Hello and welcome  :wave:
#11 Alc ONLINE
  • 7,132 Thanks
  • 7,533 posts
Posted April 15, 2016 - 05:52 AM
Welcome to GTTalk ! Will you be using your tractor for work or show ?
  • jpackard56 said thank you
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 15, 2016 - 07:22 AM
:welcometogttalk:
  • jpackard56 and Paulsadog have said thanks
#13 jimmy G ONLINE
jimmy G
  • 1,269 Thanks
  • 807 posts
Posted April 15, 2016 - 08:06 AM
I use the mobile version to scroll and reply,switch to full site version for pic's and thanks button(I kept the moderators away from better things until I did this) nice m-w could push a truck I bet
#14 shorty ONLINE
shorty
  • 5,777 Thanks
  • 5,392 posts
Posted April 15, 2016 - 08:54 AM
On the mobile version, the ✔ in the top right corner is the thanks button.
  • CraftsmanGT and Paulsadog have said thanks
#15 Paulsadog OFFLINE
Paulsadog
  • 7 Thanks
  • 10 posts
Posted April 15, 2016 - 08:02 PM
Thank you.
I would using it for tractor work. It has the 28" tiller attachment. I am going to have to remove the tines and make sure that the shaft does not have elongated cross bolt holes. Right now the outer, RH set of tines, the cross bolt holes are rather elongated and it is loose on the shaft. I think it's had a hard life but it's not dead yet!
