HD - 12 Steering Wheel.
6 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted April 14, 2016 - 05:44 AM
I can't remember, but is this steering wheel also used on a farm tractor? Need to find a good one.
  • sacsr, lindsayfl2 and kristinb1 have said thanks
#2 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,641 Thanks
  • 5,044 posts
Posted April 14, 2016 - 05:49 AM
Looks like the one on my Ferguson TO-30.  Never had it off so unsure if its splined ,keyed, tapered or what.
Edited by Gtractor, April 14, 2016 - 01:55 PM.
#3 DougT ONLINE
DougT
    Dog Approved
  • 7,072 Thanks
  • 5,058 posts
Posted April 14, 2016 - 06:19 AM
The wheel was made by Shellor.  (sp?)  Shaw used them with a key. I think Jeep used them splined.
  • LPBolens, Texas Deere and Horse, sacsr and 1 other said thanks
#4 glgrumpy OFFLINE
  • 8,719 Thanks
  • 7,973 posts
Posted April 14, 2016 - 07:05 AM
Looks similar to Power King ones.  I see them NOS on epay for around $60.  You'll have to remove and see what the shaft end is and what type needed. Good Luck with that venture. Least being all metal centered you can heat with a torch if needed, sometimes is.
  • Texas Deere and Horse and sacsr have said thanks
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 14, 2016 - 08:50 AM
Heat and a good puller
#6 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted April 14, 2016 - 01:55 PM
Same company made them for jeep and it looks close, but the center hole is larger for the jeep shaft. Tried it and it won't work, jeep one is a larger outer diameter  wheel anyway.
I rebuilt the wheel on my HD12 and the jeep with J.B WELD and it seems to be holding up good, just got to find a paint that holds up better or maybe its just my prep that I'm doing wrong.
#7 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted April 15, 2016 - 10:21 AM
IIRC, Eastwood sells a steering wheel repair epoxy and refinishing system.
