Power King V Plow $150- Ohio
7 replies to this topic
#1 jpswift1 OFFLINE
jpswift1
  • 358 Thanks
  • 343 posts
Posted April 13, 2016 - 11:04 PM
Here's a good deal on a not very common Power King Tractor V plow.
https://mansfield.cr...5524806364.html
  • Alc, Sawdust and brendajb18 have said thanks
#2 glgrumpy ONLINE
  • 6,977 Thanks
  • 6,741 posts
Posted April 14, 2016 - 04:52 PM
Good deal, now Mine, going next week-end to get. Always wanted to try one of those. Thanks for the link.
  • KennyP, Sawdust and jpswift1 have said thanks
#3 jpswift1 OFFLINE
jpswift1
  • 358 Thanks
  • 343 posts
Posted April 14, 2016 - 05:11 PM
Glad to help you out!
#4 KennyP ONLINE
  • 30,475 Thanks
  • 41,060 posts
Posted April 14, 2016 - 05:48 PM
Thought you were getting out?
  • Sawdust said thank you
#5 Cat385B ONLINE
    Therapy CAT
  • 12,338 Thanks
  • 9,200 posts
Posted April 14, 2016 - 07:30 PM
He has so many he has to plow his way out apparently.
Start in the middle, work both sides back.......
#6 glgrumpy ONLINE
  • 6,977 Thanks
  • 6,741 posts
Posted April 24, 2016 - 04:10 PM
Went today to get blade. Sunday. Long trip, but easy traffic. Took 224 till it met US30 all the way there, up 98 a little and was there. Here's some pictures. Plenty of wear on the bottom edge, needs work there and new strips. Has the 1 ft extensions but bolted up so as not sticking out much. There are two support rods where the trip springs usually are on standard blade. Not sure if correct or if it had springs when new. Would not think they would do much on a V-plow tho. I'll have to dig out the PK in the Avatar and see if it mounts OK, and if good, will tear-down for repairs and paint.
Edited by glgrumpy, April 24, 2016 - 04:14 PM.
  • Cat385B and Genem have said thanks
#7 glgrumpy ONLINE
  • 6,977 Thanks
  • 6,741 posts
Posted April 24, 2016 - 04:48 PM
Just looked in Big Red Book from PK and those rods are correct. Plane adjustment rods to keep the blade level when in use.  So glad that is right. Shows wear strips that bolt on. These are kinda bolted and welded. Welds will be cut off and new ones made to fit that bolt on. FUN!
#8 glgrumpy ONLINE
  • 6,977 Thanks
  • 6,741 posts
Posted April 25, 2016 - 04:47 PM
Any of you guys have one and can get me size of metal wear strips?  Width and thickness is what is the question. Manuals don't show sizes, just length. I may need to get taller if all the holes are worn off on main body. I have yet to tear-down to see what is there and condition.
