Need information, ford 1220 compact
2 replies to this topic
#1 propane1 OFFLINE
propane1
  • 9,156 Thanks
  • 4,284 posts
Posted April 13, 2016 - 11:40 AM
Need to replace seal at the bottom of the king pin, think that's what it's called. Anybody know how to get it apart.
Noel
  • charliewl1, darlaar3, irisbh4 and 1 other said thanks
#2 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 13, 2016 - 11:46 AM
Un bolt the 4 bolts holding the steering arm assembly on and lift it off, under that you will find the rest of the kingpin assembly nut a d such.
  • boyscout862 and propane1 have said thanks
#3 glgrumpy ONLINE
  • 8,742 Thanks
  • 7,978 posts
Posted April 13, 2016 - 04:52 PM
Didn't know, but was gonna say removing that steer link also looked like way to start at least. Sure there's much in there for seals?  Old time tractors used lots of felts that just did leak all over, but this is 4x4 I see and might have better I suppose. Sometimes the grease becomes it's own seal on most spindles.
  • propane1 said thank you
