asparagus irrigation
3 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted April 12, 2016 - 08:46 PM
  Made this up today to water our row of asparagus. I control flow with valve at the tee, drilled a 5/32" hole at each plant. Our garden has a slight slope so had the block up the lower end with bricks to make the flow even from all the holes. It should make watering them a lot easier this summer as with our low humidity the asparagus requires lots of water.
                                       Mike
  • Alc, CRFarnsworth, Rock farmer and 1 other said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,199 Thanks
  • 4,584 posts
Posted April 13, 2016 - 04:18 AM
Very clever!
Would a "soaker" hose work?
#3 Alc OFFLINE
  • 6,420 Thanks
  • 7,230 posts
Posted April 13, 2016 - 05:18 AM
Great idea ! are you going to do that though out your garden ?
  • ol' stonebreaker said thank you
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted April 13, 2016 - 07:12 AM
  Due to our hard water a soaker hose doesn't last long as it gets clogged w/ mineral deposits. The rest of the garden gets watered by a rainbird about 4' above ground and does well for everything but the asparagus.  In hindsight, which I usually have plenty of, I'm going to replace the glue on caps on the ends w/ threaded adapters and screw on caps so I can empty it after each use or I'll have mineral buildup inside and eventually start plugging holes. I'll also install a hose washer w/ screen on the connector to keep out bugs and debris.
                                         Mike
