Bolens G152 mower deck upsizing
bolens g152 60 deck snapper z6002m
30 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 14,378 Thanks
  • 10,146 posts
Posted April 11, 2016 - 07:04 PM
I know why Bolens didn't offer a 60" deck on their early imported Iseki tractors. It won't fit. I recently bought a Snapper Z6002M mower deck from a ZTR. When stuffed under the Bolens, it will not allow the front wheels to turn to the halfway point. The deck could be trimmed on the front side since it is sloped. But, that was with the mower sitting on the floor resting on it's anti-scalp wheels. If raised up to a proper cutting height, it won't fit period.
The reason I tried this is because the 48" mmm barely covers the width of the tractor. (45" with the rear wheels set 'wide') I have lots of stuff to go around on my 2.5 acres, and the narrow deck/manual tranny isn't working too well. But I really like this tractor, and want to use it to mow with.
  • Bolens 1000, boyscout862, milliebh3 and 3 others have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,378 Thanks
  • 10,146 posts
Posted April 11, 2016 - 07:06 PM
This is what the deck came off from:
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted April 11, 2016 - 07:10 PM
Possibly a deck with a different profile or blade setup would fit? Not sure but I have seen larger decks with smaller exterior bladesign fit in tight spots.Good luck!
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted April 11, 2016 - 07:16 PM
A cogged 60" snapper Snapper deck might fir but then you would have a cogged Snapper deck.I have several 60" decks that might be good for references if you have any measurements of what you need.
  • Cat385B said thank you
#5 DougT OFFLINE
DougT
    Dog Approved
  • 7,120 Thanks
  • 5,082 posts
Posted April 11, 2016 - 07:17 PM
Maybe you could salvage the spindles and fab your own deck? Maybe a 4 spindle deck?? I've got the faith you can do this. Jerome will be sooo jealous!!       :wave:
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,378 Thanks
  • 10,146 posts
Posted April 11, 2016 - 07:23 PM
I am going to try to make this into a front mount deck. My G152 has 2000 rpm front/mid mount pto, driven off the front of the engine.
I removed the gearbox off the 48 deck, but since I'm going off the front side of the pto, I'll have to flip the gear box. The gearbox cannot be flipped around internally.
The gearbox mounts to a metal plate on the 48" deck, so I can do the same here, upside down. Original set up:
  • Gtractor said thank you
#7 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted April 11, 2016 - 07:25 PM
3 point finish mower maybe? I was thinking of a bigger deck on my Yanmar 165D also, i just assumed it would fit! LOL
#8 Cat385B ONLINE
    HAZMAT CAT
  • 14,378 Thanks
  • 10,146 posts
Posted April 11, 2016 - 07:48 PM
Sorry about the multiple postings, I'm doing this off the phone.
I will have to rear mount the gearbox on the deck:
My main concern is the framework to attach the deck. Because the gearbox has to go on the back of the deck, it will have to sit quite a bit out front of the tractor. I'm worried about the flex/twist that will exert on the mount. I am going to try going off the tabs that hold the snowblower frame, and use swivel caster wheels out front.
  • Gtractor and Alc have said thanks
#9 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted April 11, 2016 - 08:21 PM
You may want to look at the bolens ek or gk for some ideas on mounting and such they are very good front mount assemblies. Good luck.
#10 Cat385B ONLINE
    HAZMAT CAT
  • 14,378 Thanks
  • 10,146 posts
Posted April 11, 2016 - 08:30 PM
JD makes 42" & 44", 3 blade decks. I have been looking for spindles and blades off of one of those for a while. I was going to try for a 54-56" rear discharge mmm deck.
#11 wilberj ONLINE
wilberj
  • 5,098 Thanks
  • 5,626 posts
Posted April 11, 2016 - 09:15 PM
I don't know how I can be jealous of a fake Bolens with a fake deck.       Here kitty kitty.  :poke:
#12 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted April 12, 2016 - 07:10 AM
This is how my Furd is set up.
  • Alc and Cat385B have said thanks
#13 Cat385B ONLINE
    HAZMAT CAT
  • 14,378 Thanks
  • 10,146 posts
Posted April 12, 2016 - 05:42 PM
Which will pull any of your teeny tractors kicking and screaming across any surface if I were to hook onto them.
  • jimmy G said thank you
#14 DougT OFFLINE
DougT
    Dog Approved
  • 7,120 Thanks
  • 5,082 posts
Posted April 12, 2016 - 07:31 PM
I don't understand how you can call that a fake Bolens? Bolens put their name on it and marketed it. It must have been a part of the Bolens line up. The big deck will be one of those rare prototypes that just never made it into production.
#15 wilberj ONLINE
wilberj
  • 5,098 Thanks
  • 5,626 posts
Posted April 12, 2016 - 08:04 PM
Because its a inside joke that makes cats hair stand up.
You said any of my tractors right? Not just bolens?  Oh you may of messed up on that little detail. :D
Edited by wilberj, April 12, 2016 - 08:09 PM.
Also tagged with one or more of these keywords: bolens g152, 60 deck, snapper, z6002m
