Kohler K321AQS Piston # 237406
6 replies to this topic
#1 Thomas Wheeler OFFLINE
Thomas Wheeler
  • 20 Thanks
  • 3 posts
Posted April 11, 2016 - 06:26 PM
Does any one know if that is a standard size piston or is it an over sixed piston?
I have looked at the manuals and non seem to have this # 237406
thank you for nay help you can give me!
Tom
  • youngsi18 said thank you
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 11, 2016 - 06:39 PM
Looks to be standard..Not positive though http://www.repaircli...3337343036&mr=1
  • Thomas Wheeler said thank you
#3 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted April 11, 2016 - 07:02 PM
Thats not a part number thats a casting number
Check the top of the piston and see if any markings if nothing or you see a 'STD" "O"  or nothing its standard
Oversize will always have the size stamped right into the top of the piston.
  • limebuzz, Alc, Cat385B and 2 others have said thanks
#4 M.Cain OFFLINE
M.Cain
  • 185 Thanks
  • 158 posts
Posted April 11, 2016 - 07:30 PM
I have also seen them factory that was.003  like the guys said look on top of the piston.
  • Auburn David and Thomas Wheeler have said thanks
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 11, 2016 - 07:33 PM
I learned something..thanks guys!
#6 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted April 11, 2016 - 08:18 PM
the standard bore for a K321 is 3.500"
the new standard piston size is 3.4945 max/ 3.4938 min
replacement sizes are .003, .010, .020 and .030
  • ducky, limebuzz, Cat385B and 1 other said thanks
#7 Thomas Wheeler OFFLINE
Thomas Wheeler
  • 20 Thanks
  • 3 posts
Posted April 12, 2016 - 09:50 AM
Thank you folks,
All I have at this point is that number 237406 stamped in the top of the piston.
I have been doing some more talking with techs and I am finding that on the inside of the bottom of the piston skirting, it should be stamp if it is .003 .010, .020 or .030 over, other wise it is standard.
I will have to pull the piston to look and see what it is!
I will let you know what I find!
  • limebuzz and lyall have said thanks
