1650 cc left turns shorter than right
5 replies to this topic
#1 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted April 10, 2016 - 10:08 PM
just bought a 1650 right turn wider than left what would you suggest the problem is? thanks
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted April 10, 2016 - 10:45 PM
Not sure but you may have adjustable tie rods and turning one side in and the other out the same amount of turns should bring your steering back in line.
  • CanadianHobbyFarmer and bill edler have said thanks
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 11, 2016 - 04:05 AM
   Not really an uncommon problem, I have a few tractors the same way,
        Pete
  • bill edler said thank you
#4 James Bosma ONLINE
James Bosma
  • 1,321 Thanks
  • 655 posts
Posted April 11, 2016 - 05:59 AM
What side does the grass discharge from the deck. It  could be built that way if grass discharges on the right and use the left side for going tight around things like trees etc.
#5 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted April 11, 2016 - 07:36 AM
The easiest way to fix that is to unhook the linkage at the steering box, then run the box all the way to the left and then all the way to the right counting the turns and then turn it back half way. You will then be able to see how far of the linkage is from going back in the hole and you can adjust accordingly, make sure the front wheels are straight during this process and also note that you will most likely have to remove the steering wheel and straighten it since it will be off center.
  • Eric and bill edler have said thanks
#6 Genem OFFLINE
Genem
  • 78 Thanks
  • 55 posts
Posted April 11, 2016 - 08:39 AM
My Massey is made that way because the right front tire would hit the pulley/belt on a full right turn and driving over a bump. Gene
