3 point for GT-1650 (MTD 990 in disguise)
#1
OFFLINE
Posted April 10, 2016 - 07:14 PM
- TheFarm2004, coldone, Alc and 6 others have said thanks
#2
OFFLINE
Posted April 10, 2016 - 08:07 PM
Is that blue piece a Sears hitch?
Seems like the geometry between that and the center link is odd?
How is it for lifting?
Joe
- Walkinman1 said thank you
#3
OFFLINE
Posted April 11, 2016 - 02:39 AM
Looks good, you may want to put a yield slot in your rods going front to the lift linkage, if it's too solid it may bend something.
#4
OFFLINE
Posted April 11, 2016 - 04:56 AM
Looks to be working well!
#5
OFFLINE
Posted April 11, 2016 - 08:32 AM
That blade is a Sears blade so yes, good eye. The geometry there is pretty odd as the center link is a bit long for the Sears stuff but it actually seems to work just fine. I thought I'd have to make a shorter top link just for the Sears stuff but I may not even bother with it unless it causes issues with my other Sears attachments.That's quite a worker!
Joe
- Rock farmer said thank you
#6
OFFLINE
Posted April 11, 2016 - 08:34 AM
On the 990's (at least the later ones or the White version that I have) it's slotted where the hydraulic ram hooks up underneath the tractor so it's got several inches of float and I set the length on the lift rods so I can't apply any downpressure, I just add weights to the blade as needed.Looks good, you may want to put a yield slot in your rods going front to the lift linkage, if it's too solid it may bend something.
