Toro 322D Spring Workover!
10 replies to this topic
#1 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 10, 2016 - 06:20 PM
Been gathering things to get the 322D going this Spring. New battery, fuel & oil filters. Oil change and sharpen blades are next weekend. About $175 so far! One fuel filter is $45! But it needs it!
  • Bolens 1000, Gtractor, Texas Deere and Horse and 4 others have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 10, 2016 - 07:57 PM
I have a 328D..zero turn bush hog...LOL
#3 Genem OFFLINE
Genem
  • 78 Thanks
  • 55 posts
Posted April 11, 2016 - 09:26 PM
What method did you use to determine that you needed a new filter? Days on the calendar or hours on the meter? I have never changed fuel filters thinking that I would know when needed it would become sluggish. Am I thinking wrong? Gene
#4 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 12, 2016 - 02:29 AM
I haven't a clue when these were changed. Wanted to do them last year, but didn't. So figured I could start fresh this year. This fuel filter is a water separator also and has the drain valve on the bottom.
  • wvbuzzmaster said thank you
#5 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 12, 2016 - 04:38 PM
Got some time today and installed the new battery. A little glow plug time and she fired off! Got the oil/filter changed. Had an issue with the switch, so Steve took it apart and cleaned it. Works now. My other fuel filter will be in this weekend, so I'll do both at the same time! I'm also going to make a cover for the dash panel. Partial Plexiglass to see the gauges, but enough to keep the moisture out of the ignition as I have had this start by itself twice during a storm!
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 12, 2016 - 05:37 PM
Camera broken?
#7 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 12, 2016 - 05:56 PM
Camera broken?
It was still in the house!
  • Cat385B said thank you
#8 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 13, 2016 - 12:13 PM
Here ya go, Cat! I had time today to make the cover for the dash panel. Nothing fancy, just to keep rain out of the switch. I'll get it put on when the rain lets up!
It's a little damp out there!
  • wvbuzzmaster and Cat385B have said thanks
#9 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 13, 2016 - 05:35 PM
Got the cover on! This is what is under the original cover.
#10 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 15, 2016 - 06:21 AM
Got the fuel filter for the bottom of the fuel pump yesterday. Cute little sucker.
These are a little hard to find by the Toro #'s. It is 43-2550. Finally got it crossed over to something I could find a filter with.  This is a Sure Filter # SFF 2150.
It also crosses to a Yanmar 129535-52150
#11 KennyP ONLINE
  • 38,321 Thanks
  • 45,910 posts
Posted April 16, 2016 - 06:17 PM
Got the fuel filters changed. Sharpened the RH blade some. Added some 30W to the hydro. Mowed an acre with it and all is fine.
Saw this leakage at the injector pump when bleeding the air out. I tightened the 4 bolts a bit more to see if that helps.
