100 & 200 series sleeve hitch on 300 series?
9 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,592 Thanks
  • 1,475 posts
Posted April 10, 2016 - 03:42 PM
I put an ad up on kijiji looking for 300 series sleeve hitch, some guy said that the hitches were similar.
Will the 100/200 series sleeve hitch fit on 300 series tractor?
I would be hoping for it to work with minimal modifications...
  • CanadianHobbyFarmer said thank you
#2 truck21 ONLINE
truck21
  • 506 Thanks
  • 287 posts
Posted April 10, 2016 - 04:15 PM
They should be the same except for the lift rod.
#3 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted April 10, 2016 - 04:32 PM
I may be mistaken, but I thought it was you who said you were taking welding shop next semester? I made a sleeve hitch for my Bolens in a few hours and mostly from scrap metal, working off the tailgate of my truck. I am not familiar with JD's, but if it is going to cost you $100 or more for a sleeve hitch  and you have to work on it to make it fit, you might be better off to start from scratch, depending on what you have laying around for resource materials. I don't recall the total cost on mine, but it is well under $100 Canadian, including the lift arm.
Jim
  • DH1 and propane1 have said thanks
#4 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted April 10, 2016 - 04:59 PM
The JD sleeve hitches are interchangeable between the 200 and 300 series. The difference is the lift rod.
  • Greasy6020 said thank you
#5 Greasy6020 ONLINE
Greasy6020
  • 1,592 Thanks
  • 1,475 posts
Posted April 10, 2016 - 05:00 PM
Jim
About that... Apparently I took wood shop, or someone decided for me that I was taking woodshop
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 14,289 Thanks
  • 10,116 posts
Posted April 10, 2016 - 06:15 PM
From this pic stolen from Dayton King: the 100 series flat fenders and the 200 series use the lift point in the center, the 300 series use the one on the right.
  • Trav1s, Leonard VanCamp, Greasy6020 and 1 other said thanks
#7 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted April 10, 2016 - 08:01 PM
 I "wood" have to say that a sleeve hitch made of wood , "wood " probably not stand up very well.  I am a carpenter, I build things from wood for a living. Houses mostly. Is it really impossible to switch classes now? Do you have a buddy taking welding?
Jim
#8 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted April 10, 2016 - 08:51 PM
If you are looking around to buy one... I have seen them anywhere from $100 to $300, depending on condition. I have been lucky enough to have found a few tractor graveyards close by and got them for pretty cheap in rough condition. But I buy most of my stuff in non-working or rough condition and redo it.
Edited by easternharvest, April 10, 2016 - 08:51 PM.
#9 Greasy6020 ONLINE
Greasy6020
  • 1,592 Thanks
  • 1,475 posts
Posted April 11, 2016 - 10:27 AM
So to get it straight, the 200 series hitch fits on the 300 series but uses the attaching point on the right?
If so, how do I build my own lift rod? I mean the one that runs from the mower deck cylinder to the hitch...
#10 Greasy6020 ONLINE
Greasy6020
  • 1,592 Thanks
  • 1,475 posts
Posted April 11, 2016 - 10:29 AM
Jim
No and no... I'm sure if I talk to the welding teacher and bribe him with cash I can get some stuff done though...
