Simplicity 7119 Hydraulic fluid
1 reply to this topic
#1 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted April 10, 2016 - 12:19 PM
How do you check hydraulic fluid in a simpliticy 7119 hydro and what kinda of fluid should i use?
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 10, 2016 - 01:18 PM
Should be ATF, Type F. If you can't find that, Dexron will work.
If your fluid isn't red, there is probably just multi-purpose hydraulic oil in there.
There should be a fill tube at a 45° angle on the side of the trans, with a cap. Fluid level should be right to the cap.
  • rustyoldjunk and Rocking416 have said thanks
