Tips/tricks for tubing your tubeless tires?
31 replies to this topic
#16 KennyP ONLINE
  • 30,381 Thanks
  • 41,010 posts
Posted April 09, 2016 - 03:52 PM
First thing I would do is check to see if the beads are leaking! No sense for a tube if it's just a bead leak!
  • Cvans and easternharvest have said thanks
#17 motobreeder OFFLINE
motobreeder
  • 425 Thanks
  • 611 posts
Posted April 09, 2016 - 08:14 PM
instead of using screwdrivers to break the bead, I was told to use a piece of 2x6 cut on a diagonal.  The wood is unlikely to puncture the tire or scratch the rim.
  • sodisr and easternharvest have said thanks
#18 Genem OFFLINE
Genem
  • 72 Thanks
  • 51 posts
Posted April 09, 2016 - 08:50 PM
I once took a tire off the wheel that I had used slime in it. It was a big job to clean and learned I would never again use a product like that. Maybe there was something else that caused it, but it sure made a mess. I use a tube now to repair leaks. Gene
  • HDWildBill and easternharvest have said thanks
#19 easternharvest OFFLINE
easternharvest
  • 154 Thanks
  • 140 posts
Posted April 09, 2016 - 09:33 PM
So just do the old submersion test?
#20 Cvans ONLINE
  • 4,899 Thanks
  • 5,276 posts
Posted April 09, 2016 - 09:54 PM
That works but so does a spray bottle with soapy water.
If you decide to go with tubes be sure to check the inside of the tire for anything poking through that might damage the tube. Be careful that you don't get your hand poked.
  • Alc, motobreeder, HDWildBill and 1 other said thanks
#21 easternharvest OFFLINE
easternharvest
  • 154 Thanks
  • 140 posts
Posted April 09, 2016 - 11:31 PM
That's one thing I'm afraid of... want to save the original equipment tires. I think I'm going to pull them off the rim to clean and inspect. Don't want to spend the money just to poke a hole in a new tube...
By the way, after some searching, I found an outfit in NJ that sells package tube deals. For my 210 it will run $52 with S&H.
So If I find that my leaks are from the bead, how do you fix that? Pull the tire and reinstall?
Edited by easternharvest, April 09, 2016 - 11:32 PM.
  • limebuzz, Alc and KennyP have said thanks
#22 KennyP ONLINE
  • 30,381 Thanks
  • 41,010 posts
Posted April 10, 2016 - 05:22 AM
Sometimes, I can stop a bead leak by smacking the tire sidewall just above the bead. For persistent leaks, I break the bead loose and apply a good bead sealer.
  • ducky, Alc, Cvans and 3 others have said thanks
#23 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 8,715 Thanks
  • 4,847 posts
Posted April 10, 2016 - 06:16 AM
DITTO!!!
My neighbor bought a tractor that had every tire 'slimed' when he bought it..  If I could get my hands on that SOB that sold it to him I'd shake his hand with a hand full of it!!
  • Bolens 1000 and easternharvest have said thanks
#24 easternharvest OFFLINE
easternharvest
  • 154 Thanks
  • 140 posts
Posted April 10, 2016 - 08:36 AM
Thanks KennyP... didn't even know they made that.
#25 easternharvest OFFLINE
easternharvest
  • 154 Thanks
  • 140 posts
Posted April 10, 2016 - 08:40 AM
DITTO!!!
Yes, I'm definitely leaning away from the Slime. If your gonna do it.... do it right. Thanks for all that have added their perspective and advise.
Edited by easternharvest, April 10, 2016 - 08:40 AM.
#26 toppop52 OFFLINE
toppop52
  • 3,875 Thanks
  • 3,693 posts
Posted April 10, 2016 - 10:00 AM
Guys, I'm old, and I worked in gas stations when they were service stations, one trick I learned very early on, put a just enough air in the tube so it isn't flat, it will go in and stay put way easier than a wrinkled up flat one will. Also make sure no plugs, screws, nails, etc..., are sticking through the tire, if any of the inner surface feels really rough, put a patch over it, it will save your tubes.
  • KennyP, Cvans, HDWildBill and 2 others have said thanks
#27 easternharvest OFFLINE
easternharvest
  • 154 Thanks
  • 140 posts
Posted April 10, 2016 - 10:52 AM
Toppop, you're not old just "WISE"... Thanks for the tip
My dad used to own/run a Sunoco station back in the late 60's/early 70's. Much respect for the full service guys!
  • Cvans and toppop52 have said thanks
#28 HDWildBill ONLINE
  • 8,889 Thanks
  • 8,634 posts
Posted April 10, 2016 - 11:02 AM
To add to Toppop's post if you do find something in the tire, like a nail, seal the hole up before putting the tire back together.  The hole will pinch the tube and you will have another flat.
  • Cvans, toppop52 and easternharvest have said thanks
#29 toppop52 OFFLINE
toppop52
  • 3,875 Thanks
  • 3,693 posts
Posted April 10, 2016 - 09:55 PM
Forgot to to say patch all holes, thanks for filling that in!
BTW, I'm 63, that's old to most.
Edited by toppop52, April 10, 2016 - 09:59 PM.
  • limebuzz and HDWildBill have said thanks
#30 HDWildBill ONLINE
  • 8,889 Thanks
  • 8,634 posts
Posted April 11, 2016 - 09:25 AM
I have you bet by a few years, 66 so your a youngster!  :smilewink:
  • limebuzz said thank you
