K341 Engine Rebuild
3 replies to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted April 09, 2016 - 09:24 AM
I have a 16hp K341 engine that is going to be rebuilt.
The crank has been ground down 0.010, and the cylinder will be bored 0.020.
My question/problem is....I am having a difficult time coming up with the correct part numbers for the rod & piston.
I have been looking at KOHLER part numbers thinking that if I get the right KOHLER number, aftermarket numbers will be easily crossed.
If anyone can help me I would greatly appreciate it.
The complete KOHLER engine number is: Model: K341  Spec: 71179  Serial: 3023500409
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 09, 2016 - 09:34 AM
There's new style and old style piston and rods and you have to match them (Cant have one or the other)
I'll run the numbers and get you pricing as well I should be able to beat/match the good aftermarkets.
#3 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 09, 2016 - 10:17 AM
Well unfortunately with the combo you need aftermarket is not crossed in any of the well known aftermarket manufactures.
Your options are "Mahle" which is the new and improved design piston and Rod and there is also old style which there is an aftermarket rod for atleast, no aftermarket kits are available complete in the spec sizes you need.
I gave as much discount as I could, send me a PM for more info, prices include free shipping
Mahle style piston , pin , rings and rod OEM Kohler  $ 400.02
"old style"   OEM kohler Piston,Rings,pin,  & Aftermarket rod  $ 311.99
  • Bruce Dorsi and boyscout862 have said thanks
#4 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 09, 2016 - 10:47 AM
Kohler certainly dosent make it appealing to buy their piston and rods with those prices, I thought Wisconsin piston and rods were expensive until I became a Kohler dealer!
  • boyscout862, EricR and propane1 have said thanks
