Tilling Technique?
8 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted May 05, 2011 - 01:45 PM
After 10 yrs of not gardening, I bought the best Troy Bilt I could afford.
Not the Horse I wanted but a Super Bronco CRT.
The ground I'm working was a cornfield(field Corn) last year. No tilled with a lot of stalks on the ground.
Stalks have been mowed with my 318 to shred but it still leaves a lot of refuse that is not shredded well.
While I like the CRT for breaking the ground that has been untilled. Since the tines are coming up from beneath the soil it does not chop them up like a front rotatng tiller would. It tends to bunch the stalks up at the front of the shroud and then will ride upon top of the GOB.
To some degree I have fond that if I back up it drops out the gob and I can attack it in smaller bits.
Any ideas what I can do to improve on this situation?
I'll rule out one idea right off to bat. Getting a Horse is on the adgenda when I find one at a price I can afford. I'm convinced that one of each would be ideal.
One bg drawback to the CRT I have discovered is a Hilling attatcment is not available.
#2 FirefyterEmt OFFLINE
FirefyterEmt
  • 426 Thanks
  • 850 posts
Posted May 05, 2011 - 02:19 PM
That's a hard one... Personally, I would try to get them out of the garden. I was amazed that I had lot's of them poke back up.
You can't beat the Horse model though...
#3 nra1ifer OFFLINE
nra1ifer
  • 671 Thanks
  • 1,530 posts
Posted May 05, 2011 - 02:21 PM
Unfortunately, I think that's one of the characteristics of a CRT tiller. I had a Craftsman CRT for awhile. I could use that one either way; regular forward-rotating, or CRT. On yours, not being able to run in a forward-rotating mode is a limiting factor. CRT is GREAT for what it's intended for, but the only benefit I found was in using it to break new ground. To get a nicely-ground, smooth end result it takes a forward-rotating motion, from what I experienced.
I do have a 1974 Horse that I will probably never part with, I like it that much.
#4 RustyTub OFFLINE
RustyTub
  • 26 Thanks
  • 137 posts
Posted May 05, 2011 - 02:32 PM
I looked high and low for a used Horse but ended up with a MANG Jr. it was built like a tank and would bust the soil in now time. but now with the wards GT with the tiller and the Kubota I had no use for it so I sold it to a good friend. I had tried to use a friends CRT on my new garden last year and it busted up the ground but standard rotating tiller on the MANG did just as good of a job of busting up hard packed ground but left a much nicer end result.
Wish I had more info on that MANG. I would say keep an Eye on C-list for what you want. Heck last week a Horse was up for 2 bills.
  • 14,472 Thanks
  • 15,392 posts
Posted May 05, 2011 - 03:12 PM
JD, Do you have someone around you that can plow under the stalks, then you can till it how you want it...
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted May 05, 2011 - 04:23 PM
That would have been the ideal scenario, however garden season is upon us and time is not in my favor.
I had hoped to get a disc & plow for my 318 this spring. But the money ran out before I got that far.
I have managed to get 1 25X30,1- 25X60, 1- 30 X 30 patch, a 25X30 berry patch, & 6- 36 inch X30 ft rows done for the Rasberries.
So while it's tough going, it is going.
I was just hoping I was just ignorant and someone could tell me what I was doing wrong.
#7 KennyP ONLINE
  • 31,235 Thanks
  • 41,495 posts
Posted May 06, 2011 - 07:27 AM
If you plant anything with stalks this year, I would pull them out of the ground at the end of the season so you don't have that problem. That's what I did last fall and sure helped a lot.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted May 06, 2011 - 08:00 AM
I'll definately do that, I used to pull the cornstalks after I picked the sweetcorn and mowed them green and tilled them in immediatly so they would breakdown by next spring. I did that with all garden refuse.
I bought this place in December, so have to deal with what the previous owner left.
#9 nra1ifer OFFLINE
nra1ifer
  • 671 Thanks
  • 1,530 posts
Posted May 06, 2011 - 08:05 AM
That's a very good idea. I do the same thing. I run my corn stalks and okra stalks (small trees!!) through a chipper/shredder. Helps a lot!
  • trowel said thank you
