Massey ferguson 7/8 loader
8 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1748 Thanks
  • 1547 posts
Posted April 07, 2016 - 08:58 PM
I know of a small winch operated loader that I can get for cheap. It's small enough for a massey ferguson 7 or 8 I think.
Is the frame and front axle assembly up for light loader duty? I can chop a 12 front axle down to 7 size if needed, mf 12 up at the barn is a parts machine.
By light duty I mean moving small square bales of straw and or straw 2 at a time (60 pounds max for these bales), moving snow with a bucket (36" wide by 18" deep) moving sand mulch compost and dirt with the same bucket.
I also want to add the variable speed setup from the 12 to a 7, for increased control on speeds. Has anyone tried this?
So I am going to need a bucket and bake forks, bucket will be rather simple. A pair of 36"x18"X1/4" pieces of sheet metal welded together, braced with angle iron and 2 18x18x18" 1/4" thick triangles on the ends, also braced with angle iron.
The bale forks will be 4 12" spikes (giant nails essentially) placed on 7 1/2" centres in 1"X1" square tubing, with a square frame 24" tall to stop bales from falling on me when I carry 2 at a time.
So what are your opinions on my ideas?
I truly enjoy this forum because I feel you guys (girls too if you're out there!) understand what I'm saying...
#2 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted April 07, 2016 - 09:49 PM
It would be significantly better and easier to find a 10 to out the loader on.
The 7/8 won't handle it for long. Bales, ok... Snow & Dirt, no way
  • Greasy6020 said thank you
  • 15109 Thanks
  • 15570 posts
Posted April 07, 2016 - 10:59 PM
If I may ask, what needs to be fixed on the 12? Maybe fix it and build a loader for it.
#4 propane1 OFFLINE
propane1
  • 12744 Thanks
  • 5754 posts
Posted April 08, 2016 - 03:54 AM
To light of tractor. Only 400 lb or so. Only plastic bushings on front wheels. There is a low range for the 7s thou. Move the drive belt out one groove on the engine pully. Push clutch in to loosen belt so you can move it.
Noel.
  • limebuzz, MH81 and Greasy6020 have said thanks
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4256 Thanks
  • 5840 posts
Posted April 08, 2016 - 07:16 AM
WAAAAAAY too light for a loader of any type, IMO
  • MH81 and Greasy6020 have said thanks
#6 Greasy6020 OFFLINE
Greasy6020
  • 1748 Thanks
  • 1547 posts
Posted April 08, 2016 - 12:40 PM
Needs new tires and rims, motor is in unknown condition transaxle was locked up (full of ice) lots of rust, no key, fuel tank is full of crap...
even then... I'm sure I can sucker my dads friend into trading his massey ferguson 12 that was my grandpas for my crapsman 6 speed. He just wants something that mows the lawn.
  • limebuzz, MH81 and Texas Deere and Horse have said thanks
  • 15109 Thanks
  • 15570 posts
Posted April 08, 2016 - 01:05 PM
I think having a good 12 with a parts 12 is the way to go. IMHO
  • limebuzz and Greasy6020 have said thanks
#8 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 08, 2016 - 05:23 PM
As said already, it's not a good idea to try a loader on a 7 or 8. You'll just
break the poor little thing. Try to get that 12. You should own grampa's machine anyway.
  • limebuzz, ENafziger, propane1 and 1 other said thanks
#9 Greasy6020 OFFLINE
Greasy6020
  • 1748 Thanks
  • 1547 posts
Posted April 08, 2016 - 11:18 PM
i agree. Heck, I want to bring it home, fix it till it runs like it should (without grandpa knowing!!) and bugger off to his house with it and some implements, go work up his garden.
