What's that little red light?
19 replies to this topic
#1 MH81 OFFLINE
  • 29,979 Thanks
Posted April 06, 2016 - 09:07 PM
My sears 12 has a red idiot light on the dash
It's sole purpose in life is to tell me when it is not charging correctly
At Daniels, it was on the whole second day.
Seems mundane enough but the problem was actually much bigger than I realized
I am going to give you all the clues that I had. You have the advantage of knowing that they are all associated
Shortly after the morning first pass on Saturday, the belt began to slip when I was trying to start the tractor
The next time I shut the machine down, it would not restart without the jumper pack.
After I got it restarted the red charge light remained on.
Battery seemed to take a charge while the jumper pack was connected but would go dead just sitting there with the key off.
By the end of the day the starter generator would turn over in the run or start position.
____________________________________
Got the machine in the garage tonight and the first thing I noticed was the generator was wobbling
After I got the tinwork off the tractor I discovered that the back end generator bold was missing .
I fix that and retentioned the belt. Still was not charging. Still was trying to start the tractor in the run position.
Thinking I had a problem with my ignition switch, I took it out, took it apart, and cleaned it all up. Tractor still tried to start in run position. By disconnecting wires one of the time I determined it was a wire that went down to the regulator.
Anyone else see it?
  • DH1, limebuzz, esbbent and 8 others have said thanks
  • 14,901 Thanks
  • 15,518 posts
Posted April 06, 2016 - 09:09 PM
So, what was the problem Alan. I'm on the edge of the couch waiting to find out!! :tapping_fingers:
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted April 06, 2016 - 09:12 PM
Looks like the regulator cover is rusted to pieces, causing a short?
#4 limebuzz OFFLINE
limebuzz
  • 1,079 Thanks
  • 1,023 posts
Posted April 06, 2016 - 09:15 PM
Did the gen.crush the regulator?
#5 EricR OFFLINE
EricR
  • 716 Thanks
  • 428 posts
Ground wire for the regulator rotted off????
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted April 06, 2016 - 09:18 PM
I retrieved the bolt and called it a lot of names. (Who found the bolt in that pic?)
Put the jumper pack on, And the tractor still tried to start in the run position
Took regulator out and found contacts welded.
Broke loose, and cleaned up the contacts.
Tractor stop trying to start itself in the run position but after it started, would still not charge.
( I am beginning to get tired of this little red light )
I took the regulator back out and really studied it
In this picture there should be a wire between the two circled pinsimage.png
After checking the rest of the regulator over and finding nothing else, I went ahead and made a new wire.
It now starts when it should and charges when it should.
The lights even work again.
Hopefully tomorrow I can get it all reassembled
  • DH1, Gtractor, limebuzz and 9 others have said thanks
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 06, 2016 - 09:23 PM
Alan, the idiot light wasnt looking for you. In fact, I bet that bolt fell out while Karen was driving LOL.
  • limebuzz said thank you
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,684 Thanks
  • 4,650 posts
Posted April 06, 2016 - 09:28 PM
Nice fix, still not sure what happened. Was the wire you made to replaced the vapor wire?
#9 MH81 OFFLINE
  • 29,979 Thanks
Posted April 06, 2016 - 09:38 PM
I had thrown the old scraps away before I thought to take a pic of it.
The new one is pretty close to what was there, just a little bigger.
No one found the bolt in the pic in the first post?
  • wvbuzzmaster said thank you
#10 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted April 06, 2016 - 09:45 PM
The photo wasn't even there when I looked at it the last time!!
  • EricR said thank you
#11 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted April 06, 2016 - 11:56 PM
Alan, i'm not sure what Larry is calling a vapor wire but what about a fusible link that was designed to burn out during a short instead of burning the tractor down? Is that the bolt hiding by the terminal at the bottom?
#12 EricFromPa ONLINE
EricFromPa
  • 4,303 Thanks
  • 3,416 posts
Posted April 07, 2016 - 04:01 AM
:wtf: Heck of a place for a bolt to fall isn't it? lol :loosing_it:
  • MH81 and CRFarnsworth have said thanks
#13 propane1 ONLINE
propane1
  • 9,744 Thanks
  • 4,517 posts
Posted April 07, 2016 - 04:56 AM
Zap !!!!
Noel
#14 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 07, 2016 - 05:26 AM
So the bolt fell across the contacts and that caused the wire to burn out? Nice fusible link!
#15 olcowhand ONLINE
  • 43,171 Thanks
  • 32,012 posts
Posted April 07, 2016 - 05:50 AM
I saw the bolt in the pic.  I have also had starter/gens not charging & found that little wire burnt in-two and simply did as you, solder a heavy wire in, and end of problem.
