need help ford 120
27 replies to this topic
#1 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
Posted April 06, 2016 - 11:57 AM
So the previous owners left behind what appears to be a 69-70 ford 120 the couple questions I have is. The red wire coming off the ignition they have going to the pto switch on the dash then going to the coil is that correct. Second the pto is disconnected so where do those wires go and third I put fuel in it yesterday and tryed to start it but the fuel dissapears and I have no clue where it is going?
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 06, 2016 - 12:12 PM
:welcometogttalk: :camera:
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 06, 2016 - 01:19 PM
Need some photos please.
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted April 06, 2016 - 01:23 PM
WELCOME.
Hopefully someone can get you a wiring schematic to look at.   Rick
  • Auburn David said thank you
#5 boyscout862 ONLINE
  • 13,556 Thanks
  • 9,431 posts
Posted April 06, 2016 - 03:01 PM
Welcome to GTT.  This may help: http://gardentractor...d120-wiringpdf/  and  http://gardentractor...erators-manual/ . When you have questions, we will try to help. Good Luck, Rick
BTW Those are very good tractors.
Edited by boyscout862, April 06, 2016 - 04:18 PM.
#6 Bill 76 OFFLINE
Bill 76
  • 2,011 Thanks
  • 1,207 posts
Posted April 06, 2016 - 03:29 PM
I am not familiar with that make but if the fuel is disappearing it may be leaking into the engine oil --carb acting up or if it has a fuel pump in could be leaking into engine if pump is bad----drain oil out and see if it smells like gas---you should change the oil anyway if you not sure when it was done last.
#7 TomLGT195 OFFLINE
TomLGT195
  • 4,054 Thanks
  • 2,901 posts
Posted April 06, 2016 - 07:46 PM
:welcometogttalk: & :wewantpics: please   It will help sort out the wires.
#8 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
Posted April 09, 2016 - 04:54 PM
Alright I finally got the spark plug to spark by cleaning up the points. Had to replace the solinoid quit getting power to the starter. I figured out where the fuel is going but this thing still won't start
#9 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
And how do I post pics?
#10 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
Posted April 09, 2016 - 05:07 PM
#11 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
Posted April 09, 2016 - 05:09 PM
#12 Dayton_King ONLINE
Dayton_King
  • 1,515 Thanks
  • 1,162 posts
Check for spark. If you have spark, pull the carb and rebuild it.
#13 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
Posted April 09, 2016 - 05:10 PM
The front tires are 5.50 they are dry rotted beyond belief and won't hold air. What size tires will fit. And she will be painted. Once I know she will run
#14 newfoundford OFFLINE
newfoundford
  • 2 Thanks
  • 25 posts
Dayton I rebuilt the carb yesterday
#15 Dayton_King ONLINE
Dayton_King
  • 1,515 Thanks
  • 1,162 posts
Posted April 09, 2016 - 05:20 PM
When I rebuild my carbs it takes some cranking to pick up gas. Have you checked your pump. Front tires are 16x6.5-8. I like these jake built tractors. Easy to work on
  • TomLGT195 said thank you
