Problems with a Briggs 9.5 OHV snowblower motor.
9 replies to this topic
#1 massey driver OFFLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted April 05, 2016 - 08:45 AM
I picked this 9.5 hp Briggs motor up to mount onto my wood splitter. Well let me tell you it has me pulling my hair out. When I bought it from the guy who was selling it he started it up and let it run for me.I figured it sounds good and starts good. He said he just added sea foam into the gas tank plus new gas. After getting home I figured I'd let it run for awhile and let it burn the gas out that was in the tank then add new stuff. I started it up fired up on the first pull and proceeded to let it run.It ran fine for 5 minutes then it died for a few seconds and started back up. Now this is what it keeps doing it will start up fine and run for awhile then shut down for a few seconds then it'll start running again then do this all over. I've pulled the carb soaked it for a couple days in heavy duty parts cleaner etc: cleaned it up and put it together started the motor and it still does it.Now seeing its the newer style motor there's no carb adjustments its that new epa stuff. The motor still dies and shuts down for a few seconds.I went and bough a new coil because I figured it was breaking down and letting the motor do this.New coil didn't make any difference it still does the same thing.Gees what am I missing ,I've worked on small engines etc: for many years and this one has me stumped. Anyone have any idea as to what I'am missing. BTW I've diconnected all the kill switches etc: to make sure they aren't the problem. The best way to describe it is that when its running its as if someone turns off the switch for a few seconds then turns it back on.What am I missing.Never ran into a problem like this before.
  • fernandofr4, eloiseqg3, debbieox4 and 1 other said thanks
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted April 05, 2016 - 08:49 AM
???  Is it getting enough fuel to the carb?
#3 massey driver OFFLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted April 05, 2016 - 09:08 AM
It sure seems like it because when it fire's back up it blows black for a second or 2.The strange part is that it will run good for a minute or 2 then act up or it will run for 5 min before acting up or will run for 15 sec the act up.Cleaned the fuel tank took out the screen in the fuel tank have a new fuel filter in line. Had the carb off a few times making sure float moves properly with no binding checked all jets and orifices with fine wire plus blew them out. I'am sort of out of ides as I've been trying many different things over the course of the last couple weeks.
#4 chieffan ONLINE
  • 11,336 Thanks
  • 7,106 posts
Posted April 05, 2016 - 09:37 AM
I had a Wisconsin on a GT that did that same thing last year.  Found that after running the gas soaked up the seal in the gas cap and closed off the vent hole.  Enlarged the vent hole in the seal and problem was gone forever.
#5 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted April 05, 2016 - 09:54 AM
Could be the vent in the gas cap, as said. Loosen the cap to let some air in and see if that changes any thing.
Noel
#6 massey driver OFFLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted April 05, 2016 - 10:09 AM
I ran it with the gas cap removed and it still did the same thing.What I haven't done yet was to replace the fuel line's. That's my next thing to do.
#7 MiCarl ONLINE
MiCarl
  • 2,206 Thanks
  • 1,122 posts
Posted April 05, 2016 - 11:29 AM
Check the valve clearance.  I've seen little scooter engines act similarly if the exhaust valve is too tight.
#8 EricFromPa OFFLINE
EricFromPa
  • 4,166 Thanks
  • 3,347 posts
Posted April 05, 2016 - 01:01 PM
Some of those engines also have Low Oil Shutdown.
Dump the sea foam fuel out yet?I don't use that stuff.Figured this new gas has enough alcohol and water in it allready,That's basically all that sea foam is.It steam cleans the combustion chamber and the isopropyl alcohol breaks down deposits (and your rubber parts) in carbs.
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 03, 2016 - 06:13 PM
  If it's blowing black smoke when it starts up again I'm guessing it's an ignition problem.
                                          Mike
#10 massey driver OFFLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted May 03, 2016 - 08:09 PM
I've had enough of this motor just going to scrap it out it's going to cost more to buy parts to try and get it going compared to buying a new one.
  • propane1 said thank you
