Kohler K321 crankcase oil breather tractor bath
24 replies to this topic
#16 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 08, 2016 - 10:35 AM
Casey, how much was it run over winter? Did it sit for a while? If it were me, I would likely change oil, maybe flush it, then give it a workout to see how quickly it returns.
I ran it only a couple times over the Winter, and checked the oil the day before plow day and the oil was perfect color, no sign of any milkyness. I am going to pull the carb, the breather, the fuel pump, and the oil drain when I get a chance and see what I can see in those areas, maybe even go ahead and rebuild or switch out the fuel pump (I have more). The fuel pump seems a most likely source of how the crankcase is refilling, especially if I determine gasoline in there.
  • shorty said thank you
#17 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,189 Thanks
  • 5,666 posts
Posted April 08, 2016 - 03:48 PM
Water or condensation in the gas gets my vote..  (the only thing that makes oil milky)  If it is run up to temp for an hour or so the water should evaporate..
#18 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted April 08, 2016 - 04:00 PM
Would gas in oil turn it milky? I was thinking it would only thin it. Also with the Kohler splash lube, could that be any part of the equation.
#19 limebuzz OFFLINE
limebuzz
  • 965 Thanks
  • 955 posts
Posted April 08, 2016 - 04:04 PM
I have an Onan right now that leaks gas into the oil. Mine isn't milky, just super runny.
#20 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 08, 2016 - 05:53 PM
I agree. Water will make it milky, but not gas.
Casey, did you by any chance grab your secret stash jug of Koolaid when you topped
up the oil last time.
  • shorty and WNYTractorTinkerer have said thanks
#21 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 08, 2016 - 05:59 PM
Not to get off the topic but your NH doesn't look like it is weighted that much. And you pulled a 12" plow ok? Is ball hollow pretty light ground?
  • wvbuzzmaster said thank you
#22 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 08, 2016 - 06:09 PM
Had 75 pounds on each tire, 80-100 pounds on the left running board. Tires are not loaded yet. Pulled a shined up 12" plow fine. Ideal weight is probably going to be around 125 on the right, 175 on the left I think. However, I was running out of horsepower and lugged the engine a few times. I will probably load the tires and get it up to about 150 pounds per each side. Im going to set up a Brinly Adapter so
I can swap to a 10" in harder ground.
#23 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 08, 2016 - 08:28 PM
Nice I had my s-16 plowing last fall, and I had 50# in each wheel and that was barely enough for a 10" without loosing traction. Planning on plowing Sunday and I added front wheel weights, and me and buddy made a weight bracket to hang those 45# suitcase weights from on landslide. So hope it
Will pull it much better than last fall. It is amazing how much weight makes a difference
#24 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 08, 2016 - 08:35 PM
Yes, weight is nice. I just made a deal on more wheel weights the other day. So now I will be perfectly overstocked on wheel weights for all my tractors. This new pair is going to allow me to take the FMC weights back off the New Holland and mount them on the Cub Cadet 108 most likely. Have other weights I want to mount to the Cub Cadet 102 for plowing, I I ever get it set up to do so lol.
By the way, are you using a sleeve hitch on your S-16, or a three point?
Edited by wvbuzzmaster, April 08, 2016 - 08:35 PM.
#25 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 08, 2016 - 08:42 PM
3pt
