float links for sears electric actuated 3pt
3 replies to this topic
#1 jakeandsears OFFLINE
jakeandsears
  • 32 Thanks
  • 68 posts
Posted April 03, 2016 - 10:46 PM
finally getting around to getting my electric hitch on my 74 ST16 and found that they make float links for the tiller attachment
here is the pdf.
http://searstractorm...s/917253146.pdf
im looking for the measurements to make a set or purchase a set any help appreciated
  • CRFarnsworth and Traill95 have said thanks
#2 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted April 04, 2016 - 06:37 AM
I don't know the size of the float links, but if your lift is like the one I have, it has a built in float. Red circle:
If you run the actuator all the way down, the arms will only drop until the attachment touches the ground. A plow, disc, tiller, or whatever, will then dig its way in. It will float up and down. As far as I can tell the early versions did not have this feature and required the floating links. I maybe wrong, but this is how it works for me.
  • jakeandsears, KennyP and CRFarnsworth have said thanks
#3 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted April 04, 2016 - 01:02 PM
Rough measurements, but maybe this will help.
1/2" rod
1& 1/2"  of 1/2"  fine thread
First bend is approximately 8" from bottom end  and is approximately 25 degrees
Top bend is 90 degrees with 1" leg and  3/16" hole
The ferrule is 1" round stock  base is 7/8" high with a 9/16" hole  Upper part is 3/4" high and 1/2" diameter with a 3/16" hole.
Each side is a mirror image of the other.
  • MH81, jakeandsears and Bmerf have said thanks
#4 jakeandsears OFFLINE
jakeandsears
  • 32 Thanks
  • 68 posts
Posted April 04, 2016 - 08:27 PM
Thank you all for your replies looks like fabricating time
