Seed Planter
8 replies to this topic
#1 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted April 03, 2016 - 07:07 PM
Here are a couple photos of the seed planter I use.  Bought it at an auction for $1 a few years ago.  Works great especially on small seeds.  Forgot to look on the back side for a brand name but I can check if someone is interested.  It has 27 different vegetables listed on the large wheel with a letter under each one.  You turn the red cup so the corresponding letter lines up with the pointer.  Seeds are placed inside the red cover.  Run it down the row and about 1/4 - 3/8 " of dirt will cover the seeds as the wheel rotates.  Nice little seeder and would not be without it.
  • Gtractor, Alc, Traill95 and 6 others have said thanks
#2 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted April 03, 2016 - 07:09 PM
I will have to look for one of those.
#3 Alc ONLINE
  • 7,235 Thanks
  • 7,584 posts
Posted April 03, 2016 - 07:12 PM
If you don't mind I would like any more info you have on it
  • CanadianHobbyFarmer said thank you
#4 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted April 04, 2016 - 07:14 AM
Will look today and see what is one it.  Nice thing about it is you can adjust the red center wheel to plant thicker or thinner.  Don't have to have it right on the pointer setting.
#5 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted April 04, 2016 - 09:34 AM
Here are 3 more photos of the seeder.  We put in 3 - 30' rows this morning, 2 different Radish and one Lettuce.   If you have a good tiller that makes a nice fine smooth seedbed that is all you need.  took twice as long to move the stakes with chalk line than it did to put the seeds in.  The large wheel has a round edge that picks up soil and drops it over the seeds.  Run the seeder down the chalk line and your done.  Couple old mini blind pieces labeled and stuck in at the end of the rows and wait for the rains to come.  Each year before use I put graphite on the washer where the red wheel turn on and also the pin the rotates on the handle for the large wheel.  The red wheel can be adjust to  a smaller or larger opening for your desired seed thickness.  I keep it out of the sun so the plastic wheel don't go to pieces from UV damage.  Think I paid a buck for it at auction as no one else knew what it was and didn't look that close.
  • Alc and oldedeeres have said thanks
#6 Alc ONLINE
  • 7,235 Thanks
  • 7,584 posts
Posted April 04, 2016 - 12:25 PM
Just did a search , old winning bids ( $12)  on ebay , but nothing else . I'll just have to keep an eye open for one .
#7 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted April 05, 2016 - 07:08 AM
I look at the current listing and nothing there.  Only the Earthway and copy cats.  I'll check CL for this area and see if anything shakes out.
Nothing found in the Midwest.  Did find that Esmay became Earthway many years ago.  Don't know if they were bought out or how that transpired.  Earthway also makes the same contraption with the Precision label.
Put a wanted on Cl.
Edited by chieffan, April 06, 2016 - 06:53 AM.
#8 oldedeeres OFFLINE
oldedeeres
  • 10,489 Thanks
  • 5,096 posts
Posted April 06, 2016 - 01:09 PM
I have one very similar to that. Like you, My Olde Deere used graphite to keep it turning smoothly. I prefer to seed the large seeds by hand, (peas, corn etc.) but it works a charm for the small ones.
#9 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted April 07, 2016 - 07:18 PM
We have a creek about 150 yd from the property.  Have enough trouble keeping the critters out of the muskmelon and tomatoes so don't bother with sweet corn.  Can usually buy it locally for around $3-$4 a dozen when it gets going good.  Can't mess with it for that.
