Adjusting PTO and PTO brake
3 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted April 03, 2016 - 04:10 PM
Have a 214 with manual PTO. Just put a new PTO brake on. This new brake is a little brake pad mounted on an L shaped metal bracket. When u install it, it's held on by a single bolt and u can slide it back and forth for adjustment when u have it mounted. There is also a threaded bolt with a spring to the left of the PTO sheave. Is there a procedure in a manual that I can follow how to adjust this crazy thing? Sometimes the sheave sticks on the clutch and won't release. Then when I shut tractor off and restart it squeals. So then I try and adjust the PTO sheave where it backs off the clutch and then it won't engage clutch for some reason? I guess it's a combination of setting that brake and the threaded bolt to the left of the PTO sheave. I already light roughed up the clutch lining with a file.
I have the manual but I don't see anywhere on how to adjust PTO.
#2 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted April 03, 2016 - 06:02 PM
Update: Aaaah I'm missing a spring...
#3 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted April 03, 2016 - 06:58 PM
I'm so.. tempted to run with that comment ... but I won't.  :D
Did you fix it?     Rick
Edited by CRFarnsworth, April 03, 2016 - 07:01 PM.
  • coinman66 said thank you
#4 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted April 03, 2016 - 08:20 PM
Checking out an exploded view to make sure I get it right lol. Who me? Get something right? Will keep u posted.
