* * * * * 1 votes
Standard Twin engine parts
12 replies to this topic
#1 matt48060 OFFLINE
matt48060
  • 5 Thanks
  • 5 posts
Posted April 03, 2016 - 02:35 PM
Hello, I am new here, this is my first post. I'm looking for engine parts for a 1934 Standard Twin. The tractor was my dads, I remember him using it when I was a kid. I remember when it broke down on him too. I was always fascinated by this tractor. For the last 40 years its been yard art. I would like to hear it run again, but it is missing most internal engine parts. Does anyone know where I could find a complete engine with the clutch?
Or, if anyone knows where I can find parts, I could go that way too.
I need pistons, pins, connecting rods, all valves, springs and retainers. I may need lifters and camshaft, but I'm not sure on those yet, they are there, I think I can reuse these. I also need the oil pan, oil pump, oil pump push rod and that plate is above the oil pan. I need one valve adjustment cover. Need the clutch assembly with the couplings and shaft that connect it to the transmission.
I think finding a engine will be easier, lol, but Ill do whatever I need too. Anyway, does anyone have any ideas? Thanks
  • CRFarnsworth said thank you
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 03, 2016 - 02:45 PM
Welcome to GTTalk.  One of our sponsors may be able to help find the parts.  I agree you might be better off trying to find a new engine.
  • boyscout862 and matt48060 have said thanks
#3 boyscout862 ONLINE
  • 12,817 Thanks
  • 9,153 posts
Posted April 03, 2016 - 03:10 PM
Welcome to GTT. Check in our Manuals Section for the Manuals that you need. I've seen several of those machines sold in my area in the last 5 years. They are around but you will have to do some searching. Try our sponsors, swap meets and tractor shows. Good Luck, Rick
  • matt48060 said thank you
#4 Clifford Bridgford ONLINE
Clifford Bridgford
  • 406 Thanks
  • 131 posts
Posted April 03, 2016 - 03:11 PM
Welcome aboard.  Your best bet is to pick up another tractor for parts.  They are well built and are pretty common to find.  Run down to the Portland Indiana swap meet this spring and I am sure you will find more than one to choose from.  They are usually priced in the $100.00 to $300.00 range here in New England.  Good hunting and keep us informed of your progress.
Cliff
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 03, 2016 - 08:37 PM
welcome to the walk-behind area. As stated above your probably better off finding a donor engine to use, as 34 was about the first yr for those. Seems to me that in 38 they added the governor to them, so if you find a 37 back it should be the same engine. You could use a newer one, actually you'll like it better with a governor.
#6 matt48060 OFFLINE
matt48060
  • 5 Thanks
  • 5 posts
Posted April 04, 2016 - 09:55 AM
Thanks for info guys. I'm going to look for another engine or tractor. Whatever shows up first. In the meantime, I'm going to look for suitable substitutes for the engine I have, just for the challenge of it. I think the most difficult part will be the oiling system. Pistons and valve will be easy, connecting rods I will probably have to have made. The clutch may be difficult too, but I'm going to search my mom's for a box of parts. Hopefully at least the clutch is around somewhere.
#7 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted April 04, 2016 - 11:36 AM
A local guy has a standard twin with plow.  He sometimes makes noises about selling it.
I could put you in touch with him it you like.
#8 matt48060 OFFLINE
matt48060
  • 5 Thanks
  • 5 posts
Posted April 04, 2016 - 12:39 PM
Sure, if he's interested in selling it.
#9 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted April 04, 2016 - 01:18 PM
I've got a chevy 4.3 v-6 if you would like to step up the h.p. a little.
Just need to figure out where to put the radiator, battery, etc...    :D       Rick​
#10 matt48060 OFFLINE
matt48060
  • 5 Thanks
  • 5 posts
Posted April 04, 2016 - 02:02 PM
Lol, no problem, there's plenty of room for all of the extras.
#11 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted April 06, 2016 - 06:59 PM
Sorry , I can't get him to answer his phone.
I'll keep trying.   Rick
#12 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted April 06, 2016 - 07:59 PM
P.M. sent
#13 matt48060 OFFLINE
matt48060
  • 5 Thanks
  • 5 posts
Posted August 07, 2017 - 08:16 PM
Well, just an update. I found donor engine, cleaned everything up and put it together. Started it up yesterday, it started right away. I just filled the carb with gas, I didnt have a good safe tank to use. I wish I wouldve had the camera further back, I didnt expect it to start right away, I jumped back a bit.
All I need now is a clutch....and the right carburetor, but the Briggs & Stratton medium Flo Jet will run it for now.
  • B10Dave, salty, Tbrooks and 1 other said thanks
