Woodruff key size
4 replies to this topic
#1 Chopperhed OFFLINE
  • 1,852 Thanks
  • 1,071 posts
Posted April 03, 2016 - 08:39 AM
Who knows the size of the key for a 77 LGT100 pto shaft.
I need to pick up a few
#2 boyscout862 ONLINE
  • 13,257 Thanks
  • 9,305 posts
Posted April 03, 2016 - 09:18 AM
You will have to use the old one to match the new. I picked up an assortment of keys at Harbor Freight years ago. It has had what I needed for atleast ten years now. I save alot of time by having a dozen different assortment boxes in my work area(keys, roll pins, cotter pins, "c" clips, hitch pins, hairclip pins, lock nuts, lock washers, and a bunch more). I've found some nice assortments at Swap Meets. Good Luck, Rick
Edited by boyscout862, April 03, 2016 - 09:19 AM.
  • Chopperhed said thank you
#3 DougT OFFLINE
    Dog Approved
  • 6,995 Thanks
  • 5,020 posts
Posted April 03, 2016 - 09:31 AM
If you don't have the old one to match up, measuring the width and length of the slot in the shaft will tell you the size.
#4 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted April 03, 2016 - 12:25 PM
These things go by number and fractional sizes. Best to take old along or the part it fits if possible. Most hardwares now have those cardboard boxes with odd stuff in them to pick thru. Sometimes you get right width, get home and too big of arc and won't fit down in. That's when the number is a better choice to make complete match. BUT, guess w/out that info you are still kinda guessing.
#5 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 04, 2016 - 05:18 AM
When you go looking for your key, make sure to get the one with tails, as they dont work out as easily as the plain half moons do.
Edited by skyrydr2, April 04, 2016 - 05:24 AM.
  • MH81 and Chopperhed have said thanks
