Nice find! Looks like a pretty straight 1253!
Got another one...
#16
OFFLINE
Posted April 03, 2016 - 09:21 PM
- SC Farmer said thank you
#17
OFFLINE
Posted April 05, 2016 - 03:21 AM
Great find, and a solid machine you have to start with there. I also 2nd the Napa battery, I bought a walmart battery in a pinch because Napa was closed. I had to change my terminal ends on my 1050 for it to work and it lasted 1 summer and died out over the next winter. They are throw away junk batteries!! I've had good luck with Napa batteries, plus I get a discount because I know people there, so that always helps!
Edited by fonz3482, April 05, 2016 - 03:21 AM.
#18
OFFLINE
Posted April 05, 2016 - 08:36 AM
Thanks for all the recommendations on the batteries. I will go with a NAPA or something similar. I tried starting it yesterday with a battery from my 1886. Nothing but a clicking noise when I turned the key. I'm thinking it's either the battery with not enough juice or a bad wire somewhere, or the solenoid, or the starter, or a seized engine. I'm thinking it's not a seized engine, because the tractor was obviously kept up and looks like it has run recently. Could be, but I doubt it (hope, hope, hope!!!). The tractor is put away for now in the barn and is a fall project, but getting it to start before then would be good.
Any advice?
Edited by SC Farmer, April 05, 2016 - 04:34 PM.
#19
OFFLINE
Posted April 05, 2016 - 08:41 AM
I believe you should be able to grab onto the flywheel or a pulley by hand and try to turn it either direction to see if its seized. If it is not then look into starting components. Sometimes if the starter is sticking, a tap with a hammer on the starter itself while clicking it over may get it going.
