1968 Commando 8 gearbox question
5 replies to this topic
#1 cranman51 OFFLINE
cranman51
  • 4 Thanks
  • 4 posts
Posted April 02, 2016 - 04:35 PM
I recently picked up a well used but maintained Commando 8 , but the dipstick for the transmission is missing, and although I found a drain plug, where is the fill hole located? The fill for my 310 8 horse is where the dipstick is located, but on the Commando 8 the dipstick is horizonal tube going from the rear of the tractor to the transmission. Thanks in advance!
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted April 02, 2016 - 04:43 PM
:welcometogttalk: :camera:
#3 boyscout862 OFFLINE
  • 15185 Thanks
  • 9997 posts
Posted April 02, 2016 - 10:23 PM
Welcome to GTT. Download the manual from our Manuals Section(its free). Good Luck, Rick
#4 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 03, 2016 - 08:14 AM
:welcome: to GTTalk.
My Daughter has an 8, but I'm several hundred miles away right now.
I thought the pipe plug up high was both fill and level test. Don't remember a dipstick at all.
If you don't get an answer before I get home Monday, please bump me with a quote to jog my feeble hat holder to remember.
#5 GWest OFFLINE
GWest
  • 703 Thanks
  • 650 posts
Posted April 04, 2016 - 07:59 PM
If this Commando 8 has a horizontal engine crankshaft the tube you are looking at is likely for the rear attachment lift cable.
Plug behind the left axle housing is where you can add oil and the lube level. It is quicker to remove the shifter and pour the oil in there.
There is also a Commando V8 that uses a vertical engine crankshaft and that transmission is totally different.
Garry
  • CRFarnsworth said thank you
#6 CRFarnsworth OFFLINE
CRFarnsworth
  • 5546 Thanks
  • 2386 posts
Posted April 04, 2016 - 08:04 PM
Garry
Yep, what he said.  I just sold a commando 8 and an 857 both had the fill/level plug in the axle hsg.
Oh yeah,  WELCOME
Edited by CRFarnsworth, April 04, 2016 - 08:04 PM.
