Rebuild kit for Zenith/Bendex carbs
17 replies to this topic
#1 Tspeyfly OFFLINE
Tspeyfly
  • 9 Thanks
  • 16 posts
Posted March 31, 2016 - 03:51 PM
Hello Everyone
Does anyone know the part number for a rebuild kit for the Zenith/Bendex, carburetor  on the 1050's I own?
If any dealers are out there please respond.
Thank's alot,
Thomas
  • Bolens800uk said thank you
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 31, 2016 - 03:53 PM
Assuming you have the original carb on there you will need this kit, Dont fall for the cheap aftermarkets as the throttle seals are not the right size.
http://bolenspartsan...or-rebuild-kit/
I also have just the gasket kit if you need to do a simple cleaning:
http://bolenspartsan...-free-shipping/
Main jets are also available but those were always sold separately
  • boyscout862 and Bolens800uk have said thanks
#3 Bolens800uk ONLINE
Bolens800uk
  • 1,810 Thanks
  • 1,196 posts
Posted March 31, 2016 - 04:25 PM
The carb on my 1254 is warped. Do you supply refurbished ones Brian? Thanks.
#4 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 31, 2016 - 04:29 PM
Nothing used but they still make them new.
Pricey at around $ 400 but I guess for a 50+ year old engine its not bad?? :anyone:
#5 Bolens800uk ONLINE
Bolens800uk
  • 1,810 Thanks
  • 1,196 posts
Posted March 31, 2016 - 04:34 PM
It is a bit pricey but I do like everything to be working and original. The other alternative is to get a old one and get it serviced again using your rebuilt kit. I think mine cannot be skimmed to even out the warping as it's too close to the float. I will put up a Wanted post shortly.
Cheers
#6 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 31, 2016 - 04:36 PM
I have used JB weld to seal a warped carb after rebuilding , if you have to take it apart just take a small chisel and it comes right off
  • LPBolens, blackjackjakexxix, Chubien and 2 others have said thanks
#7 Bolens800uk ONLINE
Bolens800uk
  • 1,810 Thanks
  • 1,196 posts
Posted March 31, 2016 - 04:39 PM
Thanks Brian.
#8 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted March 31, 2016 - 05:19 PM
#9 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 31, 2016 - 05:25 PM
Thats an L48 series zenith and takes carb kit LQ36
  • drbish said thank you
#10 Deerlope OFFLINE
Deerlope
  • 580 Thanks
  • 407 posts
Posted March 31, 2016 - 06:25 PM
You might want to give this guy a shout. I just sent a  Zenith off to him. The throttle plate rod was worn really bad. He is very good or at least he has been with me.http://www.tubeframes.com/
#11 Chubien ONLINE
Chubien
  • 645 Thanks
  • 399 posts
Posted March 31, 2016 - 07:55 PM
I bought many kits from him and even a rebuilt carb when I first started fixing these tractors and some of the stuff is not right, for example his L80 carb kits have the incorrect bushing sizes for the throttle plate shaft.
The rebuilt carb was 120$ and the throttle plate was so stiff the governor could not operate, sent it back to get fixed and he reshipped it back with the same issue. I ended up having to buy the correct bushings from Brian to fix the issue myself and get my 3 tractors up and running again.
From my experience his L63 carb kits seem OK though. I rebuilt one with no problems so I guess if you're getting him rebuild that model of zenith it would work out.
I save myself the aggravation now and buy Wisconsin kits.
Edited by Chubien, March 31, 2016 - 07:56 PM.
  • Bolens 1000, Deerlope, Bruce Dorsi and 1 other said thanks
#12 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 31, 2016 - 08:12 PM
I dont like knocking anyone but tubeframes does seem to have a "Its Close enough" motto on the parts , I think what hurts them is they are also trying to sell as cheap as possible which doesnt always work out well IMO.
I used to carry those kits because they were cheap but had way too many issues with them so I only carry Genuine parts now for them.
  • Deerlope, LPBolens, Bruce Dorsi and 2 others have said thanks
#13 Deerlope OFFLINE
Deerlope
  • 580 Thanks
  • 407 posts
Posted April 01, 2016 - 05:46 AM
Tube frames did the drive line for my 900, the shaft was so bad that he had to replace it. I did not have any issues with it.  Also as you know B 1000 that in my last order to you I ordered a kit for the Zenith carb. Since it did not include a throttle plate rod is the reason I sent it to tube frames. I have two carbs to rebuild.
  • Bolens 1000 and Chubien have said thanks
#14 Chubien ONLINE
Chubien
  • 645 Thanks
  • 399 posts
Posted April 01, 2016 - 10:40 AM
You may be right, another issue I had was with the reproduction bronze bushings for the right hub, I had bought one set and they were so tight I struggled to get the drive collar fitted back inside, I managed to do it only by getting the hub back on the wheel first in order to have extra leverage to twist the hub back on. I drove my tractor around the yard for months with no free wheel pin after that . :wallbanging:
Edited by Chubien, April 01, 2016 - 10:42 AM.
  • Bolens 1000, Bruce Dorsi and Bolens800uk have said thanks
#15 Bolens800uk ONLINE
Bolens800uk
  • 1,810 Thanks
  • 1,196 posts
Posted April 07, 2016 - 03:36 PM
I have been offered a chance to buy a carb for my Wisconsin TRA12D engine for my 1254. Can anyone identify this carb? Is this the correct one?
Thanks.
