Poor Mans Tool For Shaping Light Flat Steel And Round Rod
metal bending metal forming
15 replies to this topic
#1 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22052 Thanks
  • 7303 posts
Posted March 30, 2016 - 07:13 PM
Thought I would post a homemade tool that I use in a bench vise to bend and shape lighter flat steel and round rod.  It is a piece of 1" X 1/8" wall square tubing about 8" long with a piece of 1" x 1/8" tubing welded on one end and a rectangular slot 2" x 3/4"  made from 3 pieces of 1" x 1/8" flat steel welded together at the other end.  I have bent up to 1/2" round steel rod and 1-1/2" x 1/8" flat steel using it and bending the metal by hand.  If you want a sharp bend or are near the end of the metal you can use a pair of vise grips or a pipe wrench to form the bend.  If you want a sharp bend you can use a second pair of vise grips on the opposite end to hold the metal so that pressure is applied directly where the metal contacts the tool.  I use a drawing of the shape I am trying to match comparing the piece I am forming as I shape it and if I bend the metal too far it can be bent back the other way using the same method and applying opposite pressure to straighten it a little.  Attached are pictures of what it looks like and a couple of items I have used it to bend.  Hope it helps someone.
  • DH1, ducky, Gtractor and 25 others have said thanks
  • 15135 Thanks
  • 15577 posts
Posted March 30, 2016 - 07:20 PM
That is a very handy home made tool for sure. I have a couple pieces of steel around the shop to do things like that also.
  • HDWildBill, boyscout862 and 29 Chev have said thanks
#3 ducky OFFLINE
  • 2345 Thanks
  • 4322 posts
Posted March 30, 2016 - 07:23 PM
Man, Now I have another project.
Thanks!
  • limebuzz, HDWildBill and 29 Chev have said thanks
#4 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted March 30, 2016 - 07:31 PM
Thats nice!
  • 29 Chev said thank you
#5 MFDAC OFFLINE
MFDAC
  • 3708 Thanks
  • 1771 posts
Posted March 30, 2016 - 07:47 PM
Going to have to build these tools too!
DAC
#6 CRFarnsworth OFFLINE
CRFarnsworth
  • 5546 Thanks
  • 2386 posts
Posted March 30, 2016 - 07:54 PM
Yep,  Now I gotta have one.    Thanks.      Rick
#7 KennyP ONLINE
  • 52492 Thanks
  • 53091 posts
Posted March 30, 2016 - 08:05 PM
First of all, you need a good, well mounted vise to do this! Mine is not!
  • HDWildBill and 29 Chev have said thanks
#8 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted March 30, 2016 - 08:40 PM
Nice idea. I have used my Reese hitch on the truck or car to bend similar to this. I had a couple of jigs in mind to slip into the hitch for a larger radius.
  • limebuzz, Bmerf and 29 Chev have said thanks
#9 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted March 30, 2016 - 08:45 PM
Nice move good idea.
  • 29 Chev and retired1990 have said thanks
#10 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted March 31, 2016 - 04:03 AM
Very nice idea!
I too have used the hitch on my truck for bending things, not to mention my shins!
  • limebuzz, Alc, Sawdust and 1 other said thanks
#11 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted March 31, 2016 - 08:26 AM
I have used the truck hitch as a bender as well. It worked great for the ladder rack I made from 3/4" steel pipe. It would not have worked for something like the flatbar that 29Chev bent into a horseshoe shape (replacement belt guide for a Bolens tube frame?). I guess I will end up making a bender like that as well for odd projects.
Jim
  • Sawdust and 29 Chev have said thanks
#12 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted March 31, 2016 - 10:51 AM
This is a great idea.  Looks like I will also have a new project.  For those of us that have a hard time getting a complete picture in our mind could you please post a pic of just the complete tool?  Thanks
#13 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22052 Thanks
  • 7303 posts
Posted March 31, 2016 - 03:55 PM
Thanks for the kind words.
Pictures of the tool as requested - nothing fancy just some left over metal I had laying around - please excuse the less than perfect welding job.  I see the actual tubing length I used was 6" and not 8" as I stated in the original post but the length is flexible.  This could also be attached to a piece of square tubing that could be mounted in a trailer hitch receiver or some other secure method rather than a bench vise - I would suggest having it at chest height so you are not bent over while bending the material.  The biggest thing I have found is to have an opening that allows for you to remove the piece you are bending once it is bent.  If I was doing it again I would probably make the slot about 1" wide to allow the vise grips jaws to fit in the opening better when the metal needs to be clamped.
  • DH1, IamSherwood, Cvans and 3 others have said thanks
#14 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted March 31, 2016 - 04:37 PM
Thanks, Now I have a clear picture(s) to understand what I need to do. :thumbs:
#15 chieffan ONLINE
  • 16382 Thanks
  • 9034 posts
Posted April 06, 2016 - 07:11 AM
Works better for me too.  Now I have something to practice with my new wire welder on.  Just alight duty unit for up to 1/4" material.  anything heavier I crank up the old Lincoln.
