* * * * - 1 votes
HELP - cannot get enough spark !
30 replies to this topic
#1 MGP59DB OFFLINE
MGP59DB
  • 1,562 Thanks
  • 732 posts
Posted March 30, 2016 - 04:09 PM
Model 143402 - B&S 502727 - SN111659
This damn motor is starting to tick me off... :wallbanging:
I put in the new coil pieces today . So good coil , ...?
Tried two new condensers .
Points are good . because there is some juice flowing thru the system , enough to bite you pretty good.
But there is not enough juice to jump the spark plug gap ?
I hooked this motor to an electric motor to spin it pretty fast and can see sparks from the wire to the head .
Does anyone have any idea's on what to do next?
Only thing left is the magnets on the flywheel ... the rest is new  , wires and all.
  • chieffan and ellany69 have said thanks
#2 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,053 posts
Posted March 30, 2016 - 04:13 PM
One sure fire test is using an inline spark tester to see if you actually are getting spark under compression when the plug is in
Also are you using Genuine B&S parts ?
Edited by Bolens 1000, March 30, 2016 - 04:19 PM.
  • Lauber1, chieffan and MGP59DB have said thanks
#3 MGP59DB OFFLINE
MGP59DB
  • 1,562 Thanks
  • 732 posts
Posted March 30, 2016 - 04:26 PM
It just seems irrelevant , if I am  not getting a spark to jump the gap while the motor is turning at a good clip with the plug grounded to the head , I am pretty sure it isn't with the plug in.
This is the third one of these I have worked on this year . When everything is working good you get a lightning storm with the plug , no doubt about spark.
This is just not getting much of any.
Edited by MGP59DB, March 30, 2016 - 04:27 PM.
  • chieffan said thank you
#4 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,053 posts
Posted March 30, 2016 - 04:33 PM
Sorry misread the first post about the spark.
Are you sure nothing is grounding out , did you replace the fiber plunger that raises the points ?
  • chieffan and MGP59DB have said thanks
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,832 Thanks
  • 2,330 posts
Posted March 30, 2016 - 04:36 PM
I'm sorry if you've said this already, but is the cable itself good from the mag? The plunger I'd check to make sure it's the proper length, proper gap on SP, correct SP installed, and that you have a good ground/all wires/ cables are in tact.
  • MolonLabe, chieffan and MGP59DB have said thanks
#6 Eric OFFLINE
Eric
  • 1,317 Thanks
  • 811 posts
Posted March 30, 2016 - 04:47 PM
Just because something is new does not mean it is functional or good, I have had many new coils and plugs be found to not function. Also have found that I had the wrong type of wire for the coil I was using you know non resistor or internal resistor coil. Just my two cents good luck.
#7 MGP59DB OFFLINE
MGP59DB
  • 1,562 Thanks
  • 732 posts
Posted March 30, 2016 - 04:48 PM
Did not replace the plunger - but it appears in good condition and the gap in the points is set right . A ground some where crossed my mind - but everything appears good.
http://www.ebay.com/...=STRK:MEBIDX:IT
Put this mag on today , all wires were checked . I mean we went thru this thing 4 times - checked and rechecked.
#8 MGP59DB OFFLINE
MGP59DB
  • 1,562 Thanks
  • 732 posts
Posted March 30, 2016 - 04:52 PM
I realize this . Have had bad condensers that were new - but three in row seems unlikely .
The system is functioning but weak.
I haven't tried to start it - no point to it without spark .
We did this one - same motor type - just replaced the condenser and rewired . works great !
This one is being stubborn - I just need some ideas as to where to look for issues.
I could grab the guts from this one and see...
Edited by MGP59DB, March 30, 2016 - 05:03 PM.
#9 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted March 30, 2016 - 05:31 PM
Just my .02 cents worth here, I would take that coil down to your local shop, and match it up with a used electronic unit. The cost for an electronic coil is the same as tune up parts would be , and you never have to pull the flywheel off ever again.
I have a thread in the Panzer section with a briggs I did this conversion to. If you do go this route, use an index card between the magnets, and coil before snugging the coil. This will give you about .010 gap in between, and works EVERY time. Cheers!
Edited by stiemmy, March 30, 2016 - 05:37 PM.
  • KennyP, chieffan and MGP59DB have said thanks
#10 chieffan OFFLINE
  • 9,124 Thanks
  • 6,232 posts
Posted March 30, 2016 - 06:07 PM
I know exactly how your feel.  I went through the same thing with a S14D Wisconsin.  $200+ worth of " new" B&S parts later and no spark to the plug.  Solved the problem by jerking the engine out, shipped the head to Indiana and the rest of the tractor was sold as scrap.  Sure cured me on those S series Wisconsin.
#11 MGP59DB OFFLINE
MGP59DB
  • 1,562 Thanks
  • 732 posts
Posted March 30, 2016 - 06:19 PM
Ya I was just researching the electronic coil set-up and it might be the best way to go at this point . I just need to find the right one for this motor .
The whole machine is in such good condition that this must have been an ongoing problem . I am going to figure it out , I sure hate to waste money on Chit that don't work. I am going to solve this. One way or the other.
  • Lauber1 said thank you
#12 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted March 30, 2016 - 06:43 PM
the easiest way to make one of these work is to get a magnetron coil and flywheel from a IC briggs engine of 8hp. it will fit right on. I do this all the time with my Suburbans, which use the same engine.
  • MGP59DB said thank you
#13 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,053 posts
Posted March 30, 2016 - 06:47 PM
Its got to be something simple
Did you use Genuine B&S parts?
#14 propane1 ONLINE
propane1
  • 8,208 Thanks
  • 3,957 posts
Posted March 30, 2016 - 07:01 PM
Bad ground on the condenser ?
Noel
#15 MGP59DB OFFLINE
MGP59DB
  • 1,562 Thanks
  • 732 posts
Posted March 30, 2016 - 07:38 PM
You say I need the flywheel too?
